Outboard help
Have a question about your motor? All motor talk and questions go here.
dbeals05
Outboard help
Post by dbeals05 » 06 Jul 2016, 17:46
I was given a 1978 15 hp evinrude. It has been sitting in a barn for the last 10 years, before that it ran good. Took the top off to find a mice nest inside and the fuel line has been chewed on. Besides that i dont know much else about it
I would like to work on it myself but not sure where to start.
Good place for parts? Is it a gas and oil mix?
Model 15804B if that helps. Thanks for any help.
lckstckn2smknbrls
Outboard help
Post by lckstckn2smknbrls » 06 Jul 2016, 18:01
It is a 2 stroke motor and should use a 50 to 1 fuel oil mix.
Get rid of all the crap from the mice and inspect all the wires for damage.
RiverLife
Outboard help
Post by RiverLife » 07 Jul 2016, 08:51
Here is what I would do if it was mine.
Pull plugs and lube cylinders while slowly turning engine over by hand
check compression and spark
replace fuel lines and any other rotten hoses
rebuild carb and clean fuel filter if applicable
install fresh spark plugs gapped to spec
mix some fresh fuel from a good clean can and give it a yank, engine is liquid cooled so make sure it is in water
let it warm up and dial in carb
if it runs good change oil in lower unit along with water pump impeller
Now it is time to enjoy it on the water or sell it off. Never let a gas engine sit!
"Fish On!"
