Reducing motor vibration effect on the boat
golfrnut
20HP Tohatsu on a 1552 jon. As I have come to find out personally, and also see a decent number of posts on, they tend to produce a bit of vibration. Is it really bad, no, more of an annoyance than anything. Makes everything else rattle a bit throughout the boat though which makes it sound worse than it is.
Anyway, anyone have any remedies or purchased mounts that you can recommend to create a buffer between the motor/boat to alleviate some of it?
Same problem that we encountered with a 20hp tohatsu on a 1448. Rattled everything. Never hurt anything, just rattled. I felt that it should have run a little smoother than it did, but I'm used to yamaha-which IMO is considerably smoother-and quieter.
my 20 horse merc (sams as the tohatsu) rattled everything. if it rattled i would put a piece of rubber behind whatever was rattling. i eventually got most of the rattles out.
They make a rubber transom pad that should help out some.
Would also suggest to rubber mount anything that is vibrating.
I am still running a 15hp two stroke. It is nice and quiet and super smooth. My dads friend recently upgraded to a 4 stroke Honda and it rattles like crazy! The Honda does a better job trolling at low speed but it is heavy and vibrates a lot.
