transom saver.
hipster dufus
monroe ga
where on ur lower unit do u place ur transom saver? above the cavitation plate or below it? does it make a difference? just wondering
FWIW the guides & guys I know who "chase" tuna - from launch ramp location to launch ramp location - who are all trailering 24'+ deep-V center consoles w/ no less than 250hp motors ... DO NOT use 'transom savers' but use that 'My Wedgie' thingie that affixes to the trim/tilt rams.
Check it out - see: https://www.m-ywedge.com
Let me tell you ... these guys are Pros and use nothing but the BEST!
the My Wedge is different. I know people who use them
they are intended to protect the hydraulic trim/ tilt components, the stress is still the same on the transom
I use the same transom saver on my 24ft Grady White with a 200 Johnson as I do on my 14ter with the 9.9 hp
not only does a transom saver relieve the stress on the hydraulic components it helps protect the transom as well
mine fits both boats so it works double duty
as far as above or below the cavitation plate is doesnt really matter, whichever fits best
transom savers is one of those things people seem to argue about for whatever reason
All I know is I have used one on every boat I have owned (starting in 1978) and have never had a problem with them
I use one because it gives the lower unit more
ground clearance.
I hit a deer one morning and the motor was the only thing
that didn't hit the deer!
I run 18hp down to 3hp and the transom saver fit them
differently. Just figure out where it rides the best.
Steve A W
