16 ft Jumbo V summer project
water bouy
4
Post by water bouy »
Finally made a little progress on my 1989 Lowe 16ft Jumbo V. First thing was a better trailer with new bunks several weeks ago, not the one shown.
https://i.imgur.com/kEjRR0Ql.jpg
https://i.imgur.com/Av612ail.jpg
Next is to give it an aisle in the middle bench similar to this Lund.
https://i.imgur.com/RzenUSjm.jpg
The ribs don't line up with the front or rear of the bench so I had to rivet angle across them and to the bottom of the bench. It'll get two cross members per side. The bench is made of .040", same as the Monark I had. I'm surprised how flexible it is so it's good this is being done before cutting out the middle piece which will be about 16 inches. Home Depot has a nice 90 degree drill attachment for $18 which came in handy.
https://i.imgur.com/AsPW6E9l.jpg
All the insulation will come out so each side can be used for storage and go in new compartments along the sides. For now the plan is to use 5/8" composite for the floor with 22 gauge aluminum on each side unless something turns up between now and then that already has aluminum skin.
https://i.imgur.com/WwleBdYl.jpg
One side will get the starter battery and the other battery will go up front to spread the weight around. Undecided on a livewell. All the new stuff will get sand colored vinyl from Cabelas. Should be a lot of fun.
16 ft Sea Nymph w/30 Johnson
14 ft Monark w/25 Merc XD sold
1994 Lowe 1605 w/50 Evinrude sold
14 ft Lone Star w/15hp Evinrude sold
This topic has 48 replies
You must be a registered member and logged in to view the replies in this topic.
Register Logout
