Changing out Mono
LDUBS, before I learned about lactic acid build up in stressing smallmouth, I used light tackle and 4# Trilene XL. I changed 1/2 spool for every reel, every trip. Overkill? Yes, but I had peace of mind and confidence built up before every trip. And, FWIW, I'm certain that UV and heat are mono's worst enemy.
I use Power Pro moss green on everything, and no leaders.
I re-tie when it gets nicks or tooth marks on the end. Not very often. I also reverse the line on the reel each year so I'm using it from both ends.
Thanks. Same issue when releasing trout. Don't want to overplay them. I use 8# mono when trolling with down riggers. Otherwise, use 4# for tossing lures at trout. A lot of guys use 2#.
I'd never even heard of a FG knot, nice to know. Have any of you found a way to tell when your mono is getting stretched too much? I don't fish with it a lot and this is a reason why I don't use it much. Nothing I hate more than getting a fish on and zing, there it goes!
I can't ever remember having mono break. But when I used it, I was changing it a number of times every year.
I had lots of my bad knots come undone though.
I use braid now for almost everything except top waters. I usually use a Fluorcarbon leader with the braid.
Same here. i have never experience a break with mono. I have frequently stripped off sections that I thought might be abraded or nicked by dragging across a log or something. But never a break off while fighting a fish. I would like to test this by landing a 10 pound trout. Haha
