Bass to salt
Plentyoffish
1
Bass to salt
Post by Plentyoffish »
I have I bass tracker and the salt is taking out my carpet. I don't want to go back with carpet. Anyone know what to use instead to protect my plywood from salt water??
Sent from my LGMS210 using Tapatalk
DaleH
5
Bass to salt
Post by DaleH »
Nautolex marine vinyl - https://www.defender.com/product.jsp?id=23740
My boat is used in saltwater and is going on 21-years, everytime I think about ‘possibly’ re-doing the vinyl ... I realize it still looks good!
Plentyoffish
1
Bass to salt
DaleH wrote:Nautolex marine vinyl - https://www.defender.com/product.jsp?id=23740
Thanks! That looks alot like carpet. Have you used it before?
Dirtmonkey
2
Bass to salt
Post by Dirtmonkey »
Im working on building a 165 pro team bass tracker into a salt water flats boat. I’ve moved the gas tank to the front, I’m converting it to a center console too and mounting the batteries under it to move the weight load up front. With all of the research I’ve done I’ve decided to do 1/2”
plywood floors coated in urethane then lay down a super wet coat of urethane and apply non skid so it’s bedded and cured in it followed by deck paint. If you go this route make sure you do 5 or 6 coats on the sides of the wood because that’s where most of the moisture is able to soak into the wood.
[ external image ][ external image ]
DaleH
5
Bass to salt
Post by DaleH »
... maybe 40-years of my 50+ years of boating in the salt have had boats w/ marine vinvyl flooring. Out lasts carpet by 3-5X life in years!
Plentyoffish
1
Bass to salt
Thanks alot. Ill make sure to post some pics
fishmonger
4
Bass to salt
Post by fishmonger »
I used my old Lund in saltwater only and hated the carpeting. Here in the Lowcountry we have an abundance of pluff mud and between fishing, cast netting for bait and shrimping it seems like half of it deposited itself in my boat. I removed the plywood and pulled the carpeting off. Removed the old glue with a paint stripper and then rough sanded. Painted the plywood with grey Porch and Deck paint from Home Depot. Easy to clean up with a hose and after 3 years just rolled another coat of paint on.
Retired ... Nothing to do and all day to do it.
2001 16' Lund 25 Yamaha ... SOLD
various sailboats
Hooknhorns
1
Bass to salt
Post by Hooknhorns »
I ordered 4 rolls of hydroturf for my project, just waiting on it to come in. I’ll post pics soon!
ProduceMan
5
Bass to salt
Post by ProduceMan »
In the past I've used Tuff-Coat. It is a rubberized latex paint available from BassPro/Cabelas. Prime the wood according to their directions. It lasted the whole 8 yrs that I had my Invader I-16 and it was primarily a saltwater boat. On my current tin I used Interlux's non skid paint. Seems durable but not as grippy as Tuff-Coat.
1973 Hewescraft Big Fisherman 14
1980 Johnson 15
“I love being alive and will be the best man I possibly can. I will seek knowledge from those wiser than me and try to teach those who wish to learn from me.” Duane Allman
handyandy
5
Bass to salt
Post by handyandy »
the foam anti fatigue floor matting they sell at rural king works pretty well in place of hydro turf if your on a budget. Buddy has had it in his big 2060 flat bottom jon for two years now gets used a lot fishing the summer, and duck hunting in the winter. I was skeptical of it when he first put it down, but it is holding up just fine.
Plentyoffish
1
Bass to salt
Started ripping her apart the other day[ external image ][ external image ][ external image ][ external image ]
Plentyoffish
1
Bass to salt
Had to stop to put the radio in. I couldn't wait any longer[ external image ][ external image ][ external image ]
