FORUM UPGRADE ISSUES
Talk about anything that floats your boat (no pun intended). This is general talk about anything not related to boating/fishing.
LDUBS
3
Post by LDUBS »
Thanks Rich. I don't have Adblock. I use a MacBook. have Norton and the the Apple security/privacy settings. That is all as far as I know.
Anyway, it is working fine now.
Have Rod - Will Fish
gnappi
3
Post by gnappi »
richg99 wrote:
18 May 2019, 14:02
IF...you are using ADBLOCK...then you should have a small icon on the top of your screen. It will look like a Green circle with an upraised hand in it.
Click on it while you are on the Tinboats Site. It will then give you some options, but the one I use is Do Not Block Ads on pages on this Site. Then another screen pops up, and you check Exclude all. That should do it.
You can do that for any page that you want to allow ads on.
That depends on the adblocker, that's not a web page generated green circle.
Regards,
Gary (in South Florida)
Post by richg99 »
Yep.,. As I said. If one is using ADBLOCK. That is a specific program.
DO YOUR PART, STAY APART!
Alphawolf
Server Admin
Post by Alphawolf »
The adblocker check has been disabled. FWIW if you insert a video from a site, it will auto load the preview like this one and all I did was post the link like this
Code: Select all
https://www.youtube.com/watch?v=HG_wfMK7dko
it's magic ;)
Riverdog
5
Post by Riverdog »
Alphawolf wrote:
18 May 2019, 17:22
Code: Select all
it's magic ;)
Much easier, only problem is that it seems to have disabled my old imbedded video codes #-o . Oh well, gave me an excuse to look back through and fix them. 8)
2013 1752 Blazer SS Mercury 60/40
Jump aboard, let's take a ride. <-clicky
For those that are choosing to use the aero theme vs the pro silver, you can even change the color of the forum. Under your name on the top right, you will see a little paint brush. Click on it and choose a color....if you want. :D
Free Decal? Click here to get one!
Alvarez1112
Post by Alvarez1112 »
Is there a new process for uploading photos? I dont see the option to add files any more. It could be because I'm on my phone and not a PC.
Post by richg99 »
Test
Alvarez1112 wrote:
19 May 2019, 21:56
I will take a look! Stay tuned!
Post by richg99 »
I tried the ATTACHMENTS on the bottom of the REPLY box. It appeared to do all of the right things, but no ATTACHMENT i.e. picture appeared.
Alphawolf
Server Admin
Post by Alphawolf »
richg99 wrote:
19 May 2019, 22:06
For a picture to appear you have to "place in line"
Alphawolf
Server Admin
Post by Alphawolf »
Posted via my phone
Post by richg99 »
I couldn't find "Place in line" but it might be because the system doesn't like my pix.
I get a small yellow icon in the right corner. Clicking on it...I get... The image file you tried to attach is invalid.
Perhaps it is too large or something else? Otherwise, it is a standard JPG that would normally work just fine.
richg99 wrote:
19 May 2019, 23:00
I get the same thing, Rich! I wonder if it's the new file format for iPhones which are heic files instead of jpeg. I am playing with the settings.
Post by richg99 »
I'm using a Chromebook with standard jpg files on Google Photos. Works everywhere else.
