Could a grounding issue cause fuse burn out
Trolling motors, Fish Finders, GPS, Batteries, anything Electrical, post it here.
the hammer
Post by the hammer »
I just had to replace the fuse for the wire that runs from my car battery to the trailer hitch. I don't know what made me think about the fuse until I took the trailer tongue out from the trailer, it's a two piece trailer. I saw the grounding wire was smashed, ripped and torn with exposed wire.
Could that have caused the fuse to pop or just a coincidence.
CedarRiverScooter
5
Post by CedarRiverScooter »
I vote coincidence. Maybe there is a 2nd smashed (hot) wire.
GTS225
Post by GTS225 »
You've got a fused hot wire running to your trailer connector? If so, you may have gotten the connector into the water, and that hot shorted to ground through the water, blowing the fuse.
Roger
