Sears Jon Boats
Battery Box Hold Down Strap and Bracket:
Upgraded from a plastic hold down bracket and buckle strap to metal brackets with nylon strap and metal cam lock for my battery box. Feel better with the metal bracket and cam lock holding down my 70 lb battery!
Battery Power:
Applied power today! All systems go! Ready for a test run!
Final touches!
Finished installing front seat bungee hold down, side mounted foldable cup holders, visibility flag and transducer for my portable fish finder and battery.
Test run on Saturday!
LDUBS said:
crannman said:
Battery Power:
Hey Crannman -- if you don't mind, what is that box? I would like to enclose my TM circuit breaker in something like that.
Hello LDUBS, it’s a PELICAN 1020 Micro Case Series box. I did need to drill a small hole for the reset button to work, as well as for the circuit breaker battery and trolling motor wires. Fed cut end of wire through holes drilled in the corners. I used an exacto knife and cut the liner of the box around the circuit breaker and volt meter to have a smooth surface then mounted everything using sticky back Velcro. Drilled the hole with a drill bit made for plexiglass then shaped with Dremel router bit.
Test Run 11/21/20
Test run went very well today! Boat is dry and slipped through the water nicely! Electrical system works great!
The only thing I may consider doing is installing swivel seats!
Added a fish measuring decal with estimated weight.
Gearing up to install 2 Millennium Marine seats!
Seat mounts:
Counter bored all the mounting holes on the bottom of the mount plate that will attach to the bench seat. Outer flange of rivet nut will be recessed into the mount plate and provide more surface area for the seat mount.
Next is to drill the center holes for the pin mount, drill and install the rivet nuts and then attach the bottom seat mounts!
