tiller steering - sonar/gps mounting position
Trolling motors, Fish Finders, GPS, Batteries, anything Electrical, post it here.
DUXBWARE
2
Post by DUXBWARE »
Ok, I have a tiller steer boat. I just bought a lowrance Elite fs7 for it. I am on the fence of where to mount it. I will not use it for marking fish, just for depth reading, and for the GPS mapping/navigation.
1) Port side, right across from me when operating tiller. - seems really comfortable to view me, and most boat brands have them designed to mount here. - seems to make no sense for naviating with the GPS/mapping, as the Map won't be straight on, where the boat is heading?
2) Starboard side in front of me. (I sit on starboard Side to run tiller) - Seems fairly comfortable to view for me, definitely not awkward, but not as natural as port side. - seems to make most sense for navigating with the GPS/mapping, as it's a straight on view, in the direction the boat is heading.
Any body with a tiller than chime in on where yours is mounted, and how navigation is?
Thanks fellas. Always appreciated ! D.
kdgrills
6
Post by kdgrills »
I have a 14 foot tin tiller and a Helix 7. I made a bracket to mount it to the gunnel.
I originally mounted it on the starboard side, right at the oar lock.
I've since moved it to the port side, I much prefer it there.
There are a few pics of the starboard install in this thread:
https://tinboats.net/forum/viewtopic.php?t=46043
GYPSY400
Re: tiller steering - sonar/gps mounting position
Post by GYPSY400 »
Port side, wherever is comfortable to look quickly.
I was worried about the boat icon not being in the right direction during navigation if I mounted my Helix 7 "sideways" turns out the icon goes off of boat travel direction, not mounting orientation.
Sent from my SM-A526W using Tapatalk
DUXBWARE
2
Post by DUXBWARE »
Awesome! Thats good news, that the icon will point to boat direction. I can only assume, my lowrance would do the same.
Maybe I'll do a test run, just to make sure, before I actually decide to mount it, and drill holes, etc.
Speaking of mounts, my thoughts were to use a ram mount with a medium length arm, "C" size (1.5") balls. Where I plan to mount it, would have the arm basically horizontal. Do you think the "C" size balls, will be study enough to support the weight of the Lowrance elite FS7, or should I be considering the "D" size (2.25") balls. Problem with moving up to the D size, is the size is so much bigger/bulky, as well as they weigh so much more.
Thanks!
kdgrills
6
Post by kdgrills »
The "C" size is perfect for my Helix 7, very solid, the "D" would be way overkill. I'm sure it will work fine for you.
That's what RAM reccomends as well:
https://www.rammount.com/shop-all/power ... ELITE+FS+7
MN Fisher
Post by MN Fisher »
DUXBWARE wrote: 13 Jan 2022, 10:03 Speaking of mounts, my thoughts were to use a ram mount with a medium length arm, "C" size (1.5") balls. Where I plan to mount it, would have the arm basically horizontal. Do you think the "C" size balls, will be study enough to support the weight of the Lowrance elite FS7, or should I be considering the "D" size (2.25") balls. Problem with moving up to the D size, is the size is so much bigger/bulky, as well as they weigh so much more.
Thanks!
I've got my Garmin Striker 7 mounted on a 'B' size and have no issues - the 'C' should be more than capable.
LDUBS
5
Post by LDUBS »
GYPSY400 wrote: 12 Jan 2022, 19:54 Port side, wherever is comfortable to look quickly.
This.
The FF should have a setting that will allow how to set the boat icon. I have mine set so it is always pointing to the top of the screen. Doesn't matter the orientation of the screen to the boat.
Have Rod - Will Fish
DUXBWARE
2
Post by DUXBWARE »
Thanks for all the input guys. Very appreciated. I'll be mounting port side, with B size ram mount parts. I'll post some pics, once I git er done!
BAY BEAGLE
Post by BAY BEAGLE »
That same question was bouncing around my cranium ...... on my boat build.
Thanks!!!!
- A FLATLANDER -
nbw2019
2
Post by nbw2019 »
kdgrills wrote:I have a 14 foot tin tiller and a Helix 7. I made a bracket to mount it to the gunnel.
Is that a Mirrocraft Deep Fisherman? If so would love to see more pics of your setup, I have the same.
cheers
kdgrills
6
Post by kdgrills »
nbw2019 wrote: 17 Jan 2022, 21:17
cheers
Good eye, yes it is. I'll share a few pictures of its current incarnation this weekend.
