1978 Starcraft SUS 16ft - Rebuild and Fix'er up
Lost But Happy
Post by Lost But Happy »
Great thread! Love the in-depth electrical installs! Keep it comin! =D>
silentbravo
1
Post by silentbravo »
I have about 20+ pictures of electrical coming up next.
1978 Starcraft SUS 16 O/B
Powered by:
1993 Johnson 48 SPL - 2 Stroke 48hp Model: J48ESLETE
1998 Honda 8hp - 4 stroke Model: BF8A
Minn Kota Maxxum 80lb electric TM
Boat build log
Lost But Happy
silentbravo
1
Main Electrical Rewiring 6/20/2021
I bought the Blue Sea Systems Mini Add-A-Battery Kit - 65A, Part number: 7649
This kit comes with an On-Off-Combine switch, and an Automatic Charging Relay, that will connect to a second battery. As always Blue Sea systems parts are top notch, I'm a huge fan.
I found a spot near the main starting battery to locate the switch and ACR. Built a small panel from aluminum angle for them
I have mounted the parts to the aluminum angle and started to prewire the main battery cables here.
Just a little look at the "in progress" electrical. It takes a lot of tools and pieces to do good electrical work....
Here they are mounted to the splashwell. The starting battery sits right under this in the corner.
I added a second panel to mount breakers and an isolated ground stud. I wish I would have used the full length angle piece so I had more room for parts down there..
Here's some of the wiring coming together "behind the scenes". Big ground stud is super full, but works.
Here is the final wiring.
I'll post the wiring diagram and explanation in next post.
Powered by:
Boat build log
