Change Default Printer Reminder
DocWatson
Southern NJ
A friend on another forum wrote this little piece of code to run a reminder window to switch the default printer setting when you start your system. This is for a fellow who travels a lot and does not use the same printer all the time. I thought it was such a slick piece of business I thought I'd share it for all the road warriors out there.
Hope some find it useful.
  • PrinterMemo.zip
  • Check Default Printer Startup Reminder.doc
If I'm not mistaken, in Windows 7 you can setup default printers based on the network your connected to. This could also be a solution for those of you with newer OS's
