everything steelflex
Boating related questions, small projects, custom work and talk go here.
caten in wv
steelflex
Post by caten in wv »
thanks i dident see the price list do you just call to find out
just living the dream
Bugpac
steelflex
Post by Bugpac »
caten in wv wrote:thanks i dident see the price list do you just call to find out
Yes, they are prehistoric still... :) Dont expect to pay with your cc either. Cod or mail prepayment, Like I said, prehistoric...
caten in wv
steelflex
ok thanks i will give them a call
is300n8
Yet another steelflex question
Post by is300n8 »
I was just wondering if any of you have tried applying steelflex on a boat thats not flipped over.. My boat is a 15ft sea nymph side console and i dont feel like stripping it down again to flip it over.. any help would be appreciated thank you..
Nussy
Post by Nussy »
It would be really hard to apply upside down. It take a lot of work to push the product around. Nothing like rolling paint on. My recommendation for you would be to tip it on it's side and do half. Then tip it on it's other side and finish it.
Troutman3000
steelflex
Post by Troutman3000 »
Which kind should I order for my jon boat????
Troutman3000
primer then steel flex or just steelflex on bare aluminum
If you remove it to the alluminum should you use an etching primer?
Troutman3000 wrote:If you remove it to the alluminum should you use an etching primer?
No, not with steelflex. The product has no problems with adhesion.
steelflex
Troutman3000 wrote:Which kind should I order for my jon boat????
The less expensive version without the teflon.
Troutman3000
1 more steelflex question
So you need just a gallon to do a normal sized Jon boat?
Non-Teflon is the reccomendation?
What exactly should I call and order from these folks??????
Thanks,
Jason
Troutman3000
steelflex
Thanks.
1 gallon? What is the pigment?
Troutman3000
Thanks :D
steelflex
Troutman3000 wrote:Thanks.
1 gallon should be enough. The pigment is the coloring added.
We have Steelflex overload on the board. Any way to combine these?
Bugpac
Post by Bugpac »
Ok, gonna merge up some stuff here. should be everything you need to know about steelflex when its over... :)
