everything steelflex
Boating related questions, small projects, custom work and talk go here.
sdm111
Post by sdm111 »
There's tints you can buy to color it. Painting would be pointless and its thick enough imo that you would not have to put anything on the rivets prior
cat tracker
5
Post by cat tracker »
ok so I received my steelflex ( I went with the slick stuff). I have the boat sand blasted, what is the consenses on the best way to apply the stuff???
sdm111
Post by sdm111 »
If I were to do it again in hindsight I would use a trowel to spread it out and a stiff paint brush for the edges. And a second person for oh crap moments
cat tracker
5
sdm111 wrote:If I were to do it again in hindsight I would use a trowel to spread it out and a stiff paint brush for the edges. And a second person for oh crap moments
ic ic what about the initial coat, should I just roll on a thin coat? and how long should I let first coat dry before putting on the heavy coat?
Glades
5
Post by Glades »
Well after reviewing all these pages and posts here and in a lot of other forums I put the steelflex superslick on the bottom on my 14x36 jon boat w pods.
Prepped everything per all the posts.
I got my 4" foam rollers and per one post I read (don't remember who but thanks a LOT) I got a 10" squeegee from Home depot and pulled the rubber piece out and cut it in half and slid it back in to the frame so it would fit between the ribs.
I decided to do a test of the stuff so this morning I took about a tablespoon of each part, mixed it up and pored it on the one pod. I used the squeegee to spread it and then lightly brushed it (I didn't want to hit that small area w a dry roller).
It spread pretty nice and it was good to see the consistency of the mixed product.
So earlier this afternoon I got my wife to help me. I mixed 1 quart (1 pint of each) and set at it. I poured small ribbons of the mixed product on the hull on the space between the ribs one at a time.
Then I used the squeegee to spread it. THAT works AMAZING!!!! I read of others using a trowel but the flex in this was perfect.
So I spread it on the length of each section and my wife followed up with the roller making it even and also doing the raised ribs.
I went up the sides about 2" and only about half way up the front slope.
It took us 25 min and I only used that one quart and presto, we were done!
Having 2 people I think made this a pretty easy job.
Thanks to everyone's suggestions. Hopefully this may help others.
LT
Bigtuna19
4
Post by Bigtuna19 »
Will steel flex plug small cracks and seal small weeping rivets ?? And is just one coat enough protection I'm curious ?? I use the boat in the salt water mainly bays and coves
Johnny
Post by Johnny »
Welcome Aboard, Tuna !
this is a photo of the bottom of my aluminum boat with solid rivets.
the SteelFlex was applied over the existing rivets before I bought it.
I have no idea if they leaked before the SteelFlex or after.
so - it really depends on how much flex you have in your hull and
how rough any previous owners pounded it in rough waters.
IMHO - all leakers should be fixed (rebuck the rivets) prior to application of any bottom coating.
Dale recommends the G/Flex-650 epoxy made by West System and
our local Motor Guru (Pappy) recommends Super Glue to slow leakers prior to any coating.
and others have recommended Gluvit for the interior sealing process.
jus my Dos Centavos
https://www.tinboats.net/how-to-build-a-transom/
https://www.tinboats.net/varnish-vs-polyurethane/
All about Primers = https://www.tinboats.net/primer-and-paint-basics/
Paint, Thinners and Applications = https://www.paintingforpainters.com/
DaleH
Post by DaleH »
Bigtuna19 wrote:Will steel flex plug small cracks and seal small weeping rivets ?? And is just one coat enough protection I'm curious ?? I use the boat in the salt water mainly bays and coves
I'd use the G-Flex 650, only $20 for a 2-part 4-ounce (each bottle) kit around here (Nor'East US). You will only be mixing a capfull of each to do a ton of rivets. Use a little heat, as shown in link below, to allow it to weep in.
Not only is this a more co$t effective way to do what YOU need, you can get it locally and it stays adhered even when flexed.
See: https://www.forum.tinboats.net/viewtopi ... =3&t=40954
I have a few embedded links in there, so look at all of them, as one specifically addresses patching holes.
Be aware all epoxies (less special mixes) are prone to degradation to UV exposure, so topcoat it if you can. On the bottom, I just clean off the anti-fouling paint well (if used) make the seal and top-coat with new paint. But I moor my boats 24/7, so they need the AF paint.
Big-D
1
Post by Big-D »
Ok, everyone. I have a 21 foot bayrunner that needs help. It has a lot of saltwater corrosion and pin holes. I am retired and on a fixed income so I thought I would patch the holes then coat the bottom of the boat to the water line with Flex Coat. What are your thoughts? I have been told to weld it but I looked into it and it was way to expensive. so I am looking for other options, and ideas?
BAY BEAGLE
Post by BAY BEAGLE »
Read the Thread all the way threw. Tons of quality information, and helpful tips. Still going with my plan, less the "super slick" on the bottom - Changing up, & going with the steel flex for both interior and exterior. The squeegee idea, and two people to take on the task, along with 10 oz. increments measuring was very helpful. Working on the pigment color is still being evasive to me, but will nail it down shortly. Looking for the "Dessert Storm" background color for my pigment.
Now doing the homework on GLUV IT for the interior.
Thanks a bunch!!!!!
- A FLATLANDER -
BAY BEAGLE
I have not pulled the trigger; regarding applying "steel flex". Still preparing the boat and temperatures went south on me.
A question that has been asked multiple times in this thread, but never answered......
"CAN YOU PAINT OVER STEEL FLEX" ....... example: adding camouflage, using stencils over STEEL FLEX -
Thanks .....
- A FLATLANDER -
BAY BEAGLE
Here is the scoop, in regards to adding a stencil paint job over steel flex.
You will need to lightly scruf the steel coat with 200 grit, to knock the sheen off, wipe down ........ and add your stencil paint.
Per Jose at Steel Flex .......
- A FLATLANDER -
