everything steelflex
Boating related questions, small projects, custom work and talk go here.
rusmir
Post by rusmir »
So when i call what do i ask for and order .product name
Troutman3000
Post by Troutman3000 »
rusmir wrote:So when i call what do i ask for and order .product name
STEELFLEX CLEAR,
NUETRAL, WHITE #9X Good over teak deck for recoating, leaks, improve bonding where teak is no longer desired. Good for pontoons, foam ice box, photo development sink, aluminum and fiberglass.Used since 1961 for airboat bottoms.
Also it has been determined that you can panit over the non teflon type, correct?
rusmir
Post by rusmir »
Ok tx . Also another question can u paint over steelflex
Troutman3000
rusmir wrote:Ok tx . Also another question can u paint over steelflex
I have seen that a few guys have had no problem painting over it.
rusmir
Post by rusmir »
Great
Really??? Could you post the links?
I have not seen that. I have seen someone who tried, and it didn't stick.
Troutman3000
"Nussy" has said a couple of times that you can paint on it....I just took his word for it.
damifinowfish
Post by damifinowfish »
Does this help seal up those tiny leaks around rivets?
Do they make a flat non shinny type?
Damifinow Fish
rusmir
Post by rusmir »
try this .. thats how i will do it but with a high low pressure sprayer gun.. ill keep it posted
https://www.youtube.com/results?search_ ... type=&aq=f
Bugpac
Post by Bugpac »
I was told by the guy at fasco, you can not spray the non teflon steelflex...
rusmir
Post by rusmir »
The steelflex i will roll on but the paint i will spray. Give it a nice camo pattern of natural look
Troutman3000 wrote:"Nussy" has said a couple of times that you can paint on it....I just took his word for it.
Well, I would like to see the results of someone who has.
All I've seen on here is either paint that won't stick or camo clad peeling off in sheets. I Can't verify that Steelflex was the reason for either, but seeing how I've used it myself, I would think that you won't get paint to stick to it (for any extended amount of time anyway) without sanding the surface, which (for me) defeats the reason of why I used it.
Troutman3000
I intend to ask about this when I order mine this week. How long does it take to get it?
Nick Jones
Post by Nick Jones »
I am painting the steelflex that is on the sides of my boat. I just got through self etching the entire boat this weekend. I roughed up the sides with 150 sandpaper and self etched it again. I left the bottom of the boat alone. I plan to Camo it this upcoming weekend if my stencils come in. I guess just check my post out in the next few weeks to see if it bonded correctly.
Nussy
Post by Nussy »
Fasco told me you can only paint the standard Steelflex. The 2000 version has teflon and paint won't stick to it. You also can't apply the 2000 in multiple coats. I recommend the regular stuff.
P.S. I believe Dearl painted over Steelflex in his build. I chose to just use colored Steelflex instead.
