battery pack for my fishfinder
if lookingfor the rechargable type, try batteriesplus, they have stores in most larger cities and should have what you're wanting. Using a small lawnmower batt will last longer and not be much weight.
so i used an 8 pack AA battery holder a 9v connector rechargeable batteries and a tupperwhere bowl for my set up ill post some ice soon
Here's my setup, it's a 12v UPS battery, I only need to charge it once a month.
I use one of these batteries from Cabela's. Works great.
https://www.cabelas.com/product/Cabelas-Rechargeable-12-Volt-Battery/700551.uts?Ntk=AllProducts&searchPath=%2Fcatalog%2Fsearch%2F%3FN%3D%26No%3D40%26Ntk%3DAllProducts%26Ntt%3Dbattery%26Ntx%3Dmode%252Bmatchall%26WTz_l%3DHeader%253BSearch-All%2BProducts%26WTz_st%3D%26WTz_stype%3DSP%26form_state%3DsearchForm%26search%3Dbattery&Ntt=battery&WTz_l=Header%3BSearch-All+Products
Hey Juggernoob - nice battery boxes. Did you make them yourself? (sorry to hijack the thread)
Yeah, it's a Sterilite 0323 - Ultra•Seal™ 12.0 Cup Rectangle Food Storage Container and I cut up foam that was used for packaging hard drives that I bought. The Sterilite has a steam release vent so I put a grommet in the hole and fed some 12 or 14 gauge wire threw the grommet and put disconnects on each end. I charge the battery with the same charger for my deep cycle battery.
Brilliant! =D>
