Field tested on thousands of airboats in the Florida Everglades for over 37 years.
Super Slick is an Epoxy Coating unlike other competitor coatings.
Super Slick surface contains teflon plus additional friction reducing additive.
Same Steelflex toughness and durability proven on airboats since 1961.
Long life--Stays slippery as long as steelflex is on the boat
Can be rolled, brushed, or poured and spread.
Application and dry time same as regular steelflex.
Check us out and when you check out use coupon code tinboats.net for 10% off
https://fiberglasssupplydepot.com/FASCO-Steelflex-Super-Slick-2000-.html
