Tracker Tournament TX-17 Duck Boat Build
hookedontronics
Post by hookedontronics »
I'm gonna make a template and hit the pods with a ball pein hammer
m_barrus
6
Post by m_barrus »
Have you tested the structural integrity of the hull after you removed the seat bracing that was rivited to the side of the boat? I am doing the same conversion to my TX17 and when I went to move the boat on to saw horses (so I can work on the trailer) I had quite a bit of twist flex from the bow to the stern. I was thinking that it was due to the bracing on the sides coming higher where the seats were. I was thinking about adding catwalks from the front deck to the back seats to add back the structural integrity. Or is that over kill? Or are you not seeing the same thing that I am experiancing?
hookedontronics
Once I got the rear piece welded back in the transom was solid. I also put the angled pieces back that to from the floor to the transom and my rear bench seat will weld to that transom just for overkill. I don't have any flex
Bmac
Post by Bmac »
hooked, I've been following this thread as well. I gutted a pro17 a while back for a tiller cat/duck boat conversion. Have most of everything bought. Just now getting the time to work on it again. I'll revive that thread when I get more done. I have to reinforce my sides a lil,because the pro doesn't have as many ribs coming up the sides. I'm also moving the fuel tank and trolling batts under a shortened front deck. I'll end up with 12 1/2' of open deck. Wasn't planning on adding pods,but anxious to see how yours acts with them.
Are you planning on rattle canning your camo on? I've been looking at different DIY paint jobs out there,and haven't really seen anything I like. I'll be doing more open water hunting than marsh,so the large patterns on the new factory jobs is the way I'm leaning. That'll make it tougher to match seats and rubber matting on the floor.
hookedontronics
I'm gonna do a spray paint camo stencil, probably kW-1
spcamno
Post by spcamno »
Very nice build!
I would like to know how to strengthen the side as well because I am working on a similar project (another duck boat and the platform was originally a Sylvan 1750 pro bass which is very similar to the bass tracker).
Any tips will be very much appreciated!
Bmac
Post by Bmac »
spcamno, I'll show you how I stiffened mine in a few days.
spcamno
Post by spcamno »
Bmac wrote:spcamno, I'll show you how I stiffened mine in a few days.
Awesome thanks Bmac!
Look forward for your info as I will start tackle it in a week or so once I replace a few worn rivets.
Cheers
hookedontronics
Boats been sitting awhile so i took the day off work yesterday and my buddy and I got back at it.
Big_ug_chevy
6
Post by Big_ug_chevy »
Nice work on the pods, I want to put some on mine but just to weld them on is gonna cost me 3 or 4 hundred. No telling what they want to fabricate them...
m_barrus
6
Post by m_barrus »
I'm glad you got back on your project. Mine is in the same stage as yours and I was thinking I needed to get back on it. Now that you did, I'll have to.
Sent from my SM-G920V using Tapatalk
Prowelder
6
Post by Prowelder »
Nice
Sent from my SM-G920T using Tapatalk
Shoedawg
Post by Shoedawg »
Man this is looking awesome. Great workmanship. =D> =D> =D> I really need to learn how to weld aluminum :|
Project: Shoebox - 1746 Fisher (Remod)
https://www.tinboats.net/forum/viewtopic.php?t=33272
How to Smell Like a REAL MAN.
Combine: fuel, wood, grease, dirt, metal, BBQ, yard, coffee, tobacco juice, & beer.
Mix well. Apply to Sweaty Chest Hair using a Flannel Cloth.
"Work Harder and Smarter" - Mike Rowe
hookedontronics
Front deck and floor to deck transition piece. Coming along slow but it's getting there.
overboard
Post by overboard »
Fine job you're doing there! =D> Waiting to see it with the camo paint.
