Propeller calculator ('Prop Wizard') by Turning Point Props
DaleH
Post by DaleH »
See: https://v2.propellerwizard.com/
I like this "prop wizard" by Turning Point propellers as you can use your specific make/model boat or one as close to yours that you can find. For example, I couldn't load a Procraft tin boat from their database, but used a Smoker Craft of similar/same beam, length and type, for example.
Then you can add weight for how much gear and fuel the boat typically carries on every trip, then add for # of people aboard.
Even better than the Prop Wizard ... I love their props! I've used this for the last 5 tin boats I've rigged and the results have been awesome!
They will also exchange your prop for another one if you try one out and don't like the results!
Edit 09Sep2015: Have successfully rigged 5 tin skiffs ranging 12' to 16' using this calculator and their props now. Awesome results!
Tip - Some of the BEST prices and availability I've found for their props is https://www.lowcostboatingstore.com
Skiffing
Propeller calculator or Prop Wizard, by turning Point Props
Post by Skiffing »
Very cool!
Tkanks
Awesome! Thanks Dale! :beer:
Please use our Amazon Affiliate link. It costs you nothing and sends a few cents to the site.
Amazon Link!
Capt1972
Post by Capt1972 »
no Yamaha OB's :roll:
DaleH
Post by DaleH »
Capt1972 wrote:no Yamaha OB's :roll:
Hmmmmm, maybe not all HP motors but I had propped a 40hp Yumster 2-stroke w/ one 4-5 years ago ...
What size OB were you trying to pitch her for? Remember you can also use the calculator to help determine what the best prop would be for your rig. I've never not had a prop come up, but realize that they don't make smaller props, e.g., like for OMC 8hp motors using a shear pin.
wmk0002
Post by wmk0002 »
So can you order props on this site or only use the calculator to estimate which one is needed? I tried it and it gave me recommendations but I didn't see any ordering options.
2016 Alumacraft 1648 NCS - 2020 Yamaha 25 HP Tiller - 1992 Johnson 9.9 HP Tiller
https://www.tinboats.net/forum/viewtopi ... 21&t=40764
DaleH
Post by DaleH »
wmk0002 wrote:So can you order props on this site or only use the calculator to estimate which one is needed? I tried it and it gave me recommendations but I didn't see any ordering options.
You buy on-line from wherever is cheapest for the prop and shipping for what you want/need. If needed, Turning Point will exchange out another prop for the one you get, if not ideal after you test it. Last time I did this I paid a $15 restocking fee and shipping, directly with them (not the seller, but you could try that too).
Note - I had more posted this link to help people assess what correct propeller diameter and pitch prop they need ... not so as to endorse Turning Point props. Although that said, I really like their calculator and have used their props on many a boat now and remain fully satisfied!
wmk0002
Post by wmk0002 »
Thanks! Yes, the tool is really helpful. It recommended a prop for my boat 1" less pitch than what is currently on it which is probably accurate based on my performance. I don't know anything about the turning point brand either but the option to try out a prop and exchange for a small fee seems like a great deal to me.
DaleH
Post by DaleH »
wmk0002 wrote:I don't know anything about the turning point brand either but the option to try out a prop and exchange for a small fee seems like a great deal to me.
I checked today, the updated fee to swap out an aluminum prop is $25 and $35 for a SS prop. Where SS props run a good $200+ ... that's a good feature.
FWIW I double-checked my boat/prop performance numbers today, with a few prop gurus I have met over the years. They agreed with the recommendation of the SS prop from Turning Point and the performance was outstanding! I was only 1MPH off (actually faster to boot!) than the theoretical speed as based upon a calculation of hull type, load weight, lower unit gear ratio, RPM and prop pitch.
VinTin
Post by VinTin »
Searching Johnson.........it went back to 1996.
Looks like I'm a few decades out of luck!
driz
Post by driz »
Yea, they don't go back to the 80's for my Merc either. Strange since there are so many 80's mercs around . l am not quite there yet anyways so it will wait a while. The one thing that drives me nuts with these engines is lack of a RPM gauge. That's the real determinate for a prop anyways, WOT range. I'm a gauge guy and hate not knowing RPM's Temp, and if applicable Oil Pressure. Without those you are always wondering with this old iron.
As for the dent I can get most of it out. Lot's of the more simple end of body and fender works in my background so I know when to call it good. At least that cursed foam is gone so it can be gotten to. Who knows maybe by some stretch that dent will prove to be the reason that odd stream of water is coming off the drivers side and curling into the back of the boat. It's a stretch but makes more sense for my issue with that weird blade of water coming from somewhere down there wrapping out up and over into the back corner.
"I'm only here for the beer and yes fishing sure beats working" 1985 Tracker V17 Tournament 50 Merc =D>
WALI4VR
5
Post by WALI4VR »
Buy a inexpensive tach at most auto parts stores and hook it up!
Sent from my SCH-I545 using Tapatalk
16' Lund w/ 50hp Merc (Yami) stArtin to get old like me
Off Topic
newyota
6
Post by newyota »
Tried the wizard, but it does not ask for an older year motor as mine is an 85'.
eeshaw
2
Post by eeshaw »
All I get is a blue screen so apparently they've taken it down. Boooooooo!
DaleH
Post by DaleH »
eeshaw wrote: 17 Aug 2020, 09:36 All I get is a blue screen so apparently they've taken it down. Boooooooo!
Works for me! Checked 10:24 EST
