Propeller calculator ('Prop Wizard') by Turning Point Props
eeshaw
2
Post by eeshaw »
Works for me now. Must have been not having my coffee!
silentbravo
1
Post by silentbravo »
Going to have to look into this later, I went through the calculator and it spec'd a very different prop than what is on the motor currently. From the handful of times I have had it out, it did very nicely but if I'm leaving a decent amount of power/MPG on the table then it would be worth to change out if it's not to expensive. Plan to install a tach also, so that should give me some data to work with this year.
Thanks for the link, this is a very cool resource.
1978 Starcraft SUS 16 O/B
Powered by:
1993 Johnson 48 SPL - 2 Stroke 48hp Model: J48ESLETE
1998 Honda 8hp - 4 stroke Model: BF8A
Minn Kota Maxxum 80lb electric TM
Boat build log
old_fart
1
Post by old_fart »
silentbravo wrote: 24 Mar 2021, 21:24 Plan to install a tach also, so that should give me some data to work with this year.
Get that tachometer sooner rather than later.
-W
MadGasser
Post by MadGasser »
Link doesn't work.
