Gas tank repair parts
oakchas
5
Post by oakchas »
New here, sorry if this is the wrong place.
Working on a 14 foot Mirrocraft with an 8 horse 'rude.
Plastic 6 gal tank with level indicator on the hose connector.
Level indicator doesn't work. There's a small crack in the assembly that the hose plugs into, and occasionally, the motor gets starved for fuel, and I have to squeeze the bulb again to get her going.
It's a 70's motor and probably the tank too.
Are there repair parts, or do I have to buy a whole new tank?
Thanks for any ideas, planning on a complete redo of this boat after fishing season. But for now, it gets us to the holes, if a bit gimpily.
Skiffing
5
Post by Skiffing »
Metal tank? Junk it.
Pictures always help
Plastic - Parts available to rebuild.
Google / EBay are good sources.
oakchas
5
Post by oakchas »
Plastic tank.
Google not much help.
I'll try ebay.
Pix to come
Thanx
oakchas
5
Post by oakchas »
It's an OMC DuraTank.
Johnny
6
Post by Johnny »
Have you taken it apart yet to see how how bad the crack is ?
it may be something that you can either fix yourself or get
a suitable replacement that will allow uninterrupted fuel flow to your motor.
a quick search on the net does not show a parts breakdown for the "fuel pickup assembly".
don't toss it out just yet.
and, :WELCOME: to Water World
Maybe the parts are interchangeable:
tank fittings.jpg (74.22 KiB) Viewed 600 times
https://www.tinboats.net/how-to-build-a-transom/
https://www.tinboats.net/varnish-vs-polyurethane/
All about Primers = https://www.tinboats.net/primer-and-paint-basics/
Paint, Thinners and Applications = https://www.paintingforpainters.com/
1959 Lone Star Malibu 14'
oakchas
5
Post by oakchas »
Thanx Johnny,
I haven't disassembled yet. I got the number off the tank and will see if I can find parts that way. If I can find parts, I'll get 'em and install them. Otherwise, I can fix just about anything. But, I have to find a plastic glue suitable for the black plastic parts impervious to gasoline.
lckstckn2smknbrls
Post by lckstckn2smknbrls »
I fixed a plastic gas tank on a lawn mower with a gas and oil resistant adhesive I got at Home Depot. I can remember the name offhand. I'll try to find it out.
Watch CL for a new to you tank.
Johnny
6
Post by Johnny »
oh yea, I borrowed my brothers garden tiller and the danged squirrels
ate holes in the plastic gas tank......
seems the HDPE plastic is made with soy bean oil in it and the stupid squirrels think it is edible !!
I used the same fix as 2smknbrls - - - 4 years now and is still holding.
it is the Permatex ULTRA BLACK Maximum Oil Resistant which should seal the air leak.
Good Luck !!
oakchas
5
Post by oakchas »
Barefoot_Johnny wrote:Have you taken it apart yet to see how how bad the crack is ?
Well, my "rough carpentry" measure of my tank pickup/level indicator was 2-3/8 X 1-3/4 for the screw holes. So, metal tank parts may be an option.
Great!
But, permatex may do the trick.
Better yet!
I can take the unit out.
Probably fix the float for the indicator, glue the crack shut.
That'll work for me.
