Ad blocker detected: Our website is made possible by displaying online advertisements to our visitors. Please consider supporting us by disabling your ad blocker on our website.
ocbinva wrote:I just rebuilt the entire front end and A-arms original to a 1980 Z28. VERY serious rust. Mon - Fri I hit the nuts once in the morning and once at night. That Saturday I was able to remove everything without using a breaker bar. Next I am using it on header bolts. Best I have ever used. I also use it on vintage garden tractors and it has never failed me. Between that, vinegar, and using electrolysis I can clean up just about anything vintage.
I use it and it works great. It takes a bit of time though. For better try using your air chisel with a blunted (cut off) tip. You take that rig soak it in the mix and hammer away on the end of the bold or side of the nut . The vibration will get that oil right down in there. A guy showed me that trick on a 2" pin on an old Northcountry back hoe once. Sure works better and is far easier than beating with a BFH.
"I'm only here for the beer and yes fishing sure beats working" 1985 Tracker V17 Tournament 50 Merc
I'd been digging trying to find this thread to recall the proportions & composition of the mix (whether it was just atf & acetone or if something else were in the mix).
This is my last hope before I take a saw-z-all to the '85 60hp Merc parts motor I've got and...amputate...the block so I can get to where the driveshaft is seized to the crankshaft. All I'm after is the complete lower unit as a spare, or for ebay, but I can't separate it from the powerhead. I've got a hole through the exhaust plate at the moment so I have access to the splines on the shaft.
The FSM suggests drilling a hole in the side of the driveshaft housing and using a torch to cut the driveshaft should the situation i'm presented with develop, which is highly troublesome that it happens so often Mercury thought to comment on it in their literature.
onthewater102 wrote:I'd been digging trying to find this thread to recall the proportions & composition of the mix (whether it was just atf & acetone or if something else were in the mix.
Uhhhhh ... it's a 'sticky' post (always stays at the top of the list) under the Motors forum ...
PB blaster. But before I knew about that I used vinegar. Yes vinegar. The veterinarian I used to work for wanted to be a chemical engineer prior to vet school, he discovered that the vinegar/acetic acid would break whatever and reverse the rust process.
