Schukster 1976 Lund 14
- 7
This will be the 3rd summer that I have used my boat. I haven't had any peeling of the interior paint. As I stated in my post,on the interior I only scraped any loose paint and sanded it smooth and to scruff up the existing paint before I applied a couple thin coats of primer and paint.
As far as the battery location and listing, quite frankly the 9.8 mercury isn't enough hp to really get it up on plane. I have thought about upgrading to a larger motor but can't justify it for how I use the boat. I live on the lake so I usually just troll back to my dock. I could definitely change the battery location if needed.
Also,I usually fish by myself so the extra weight in the bow helps level me out when I'm running the tiller
Schukster
Sent from my ASUS Transformer Pad TF300T using Tapatalk
Schukster
Schukster
viewtopic.php?f=21&t=39912
- Donor
- 4
That is a sweet ride. Awesome detail. Nice and deep.
- 4
- 4
Beautiful Boat! Lots of ideas taken from your conversion. I have a 1977 Lund I'm just starting.
- 7
Thanks, Dan. I'm glad you found some things you could use for your build.
S
S
Schukster
- 5
Looks good. I have a similar trolling motor and the pedal cord reached the rear seat on my 14 ft. I'm hoping it does the same on my 16 ft.
16 ft Sea Nymph w/30 Johnson
14 ft Monark w/25 Merc XD sold
1994 Lowe 1605 w/50 Evinrude sold
14 ft Lone Star w/15hp Evinrude sold
- 5
Great work on this build, looks very professional and clean. I like how you incorporated the mid-cut bench seat that remained and turned it into storage, etc.
I am planning to do a 14ft V hull in about a month and was planning to do a similar cutting of the middle bench to help with keeping things tight and sturdy and now after seeing this build and use of that, I think I am going to for sure go a very similar route. Thanks!!
My 1986 Alumacraft Classic Deluxe project - viewtopic.php?f=21&t=41424
14 ft Alumacraft Semi-V 2nd project - https://tinboats.net/forum/viewtopic.php?f=21&t=46511
- 5
Beautiful build! How much weight did the additions add to the boat? Maybe 200-220 lbs? That's about 1/3 of your overall capacity I'm guessing.
Greg
Greg
- 7
Thanks for the comment.
I wish I had kept better track of how much weight I added. I found the specs for my boat on the Lund site. The load capacity is 795# which the coasts guard rates for a 5 person capacity. I did an estimate on the linear feet of cedar 2x4 and the 5/8 inch plywood and hardware and came up with about 200 #. The boat is definitely heavier to push around on the trailer and obviously sits a bit lower in the water. Its probably is using up about 1.5 of the 5 person rating. I would have no concerns using it to fish with three adults. The weight of my build is fairly distributed over the length of the boat.
I probably overbuilt it with 2x4 and 5/8 decking but I'm 250+pounds and wanted it to hold me. 2x2 and 1/2 inch decking would probably work for lighter folks. I'm more of a carpenter than a metal worker, otherwise aluminum would probably be lighter yet.
Schukster
Sent from my SM-S320VL using Tapatalk
Schukster
Schukster
- 5
How is the paint holding up?
I have the same Lund and am looking to do a tear down and rebuild such as yours. Fantastic work and thank you for all the pictures.
- 7
Re: Schukster 1976 Lund 14
Wow, this is the 5th summer since my refurb. Both the rustoleum topside and the rustoleum interior paint has held with no problems or peeling. I did put a scratch on the exterior by rubbing a dock bracket but that wasn't any fault of the paint. You might want to research adding a clear coat hardening additive to the exterior final coat, something I didn't do.
Sent from my SM-S727VL using Tapatalk
Schukster
