SS PROP VS ALUMINUM
scoobeb
SS PROP VS ALUMINUM
Post by scoobeb »
I'm debating on getting a ss prop over the aluminum prop I have now. The motor is a 20hp 2stroke mercury that has the standard 13 pitch prop on it now. The motor has great overall top end but I wanted to know if I switched to a 13 pitch ss prop will it get me out of the hole faster due to it's limited flex over the aluminum prop? I just want that little bit of extra torque I have been told the ss prop will give me but I want to hear from you guys and real world experience with them,switching them out. I want to know if I should stay at a 13 pitch or go bigger or smaller? I know this motor could spin a 14 without issue but will it benefit me any or just stay with a 13 or possibly go down to a 12. If anyone can chime in on this I would be much appreciated. As of now I get a unbelievable wot of 30+ mph with just me in the boat and near 29mph with 2 people plus all gear out of an aluminum prop and the torque could be a bit better out of the hole,that is my main concentration, to get better out of the hole torque while keeping or even gaining wot speed I'm getting now. If it's not going to benefit me any then I will buy the same prop just a new one and using the one on it now as a spare.
Any advantage on the quicksilver prop over a Solas prop? Any particular aluminum prop better for my 20hp,if I go ss I'm going with Solas since they make great props as far as I know,unless someone can lead me in a different direction for the best overall ss or aluminum prop,ty for any help.
dahut
SS PROP VS ALUMINUM
Post by dahut »
"Propellers are a voodoo science. Nobody really understands propellers."
- Allen Smith, professional prop builder, A.P.B.A. AND N.O.A. speed record holder.
"Many vessels enjoy little to no benefit from the use of stainless props.
They are expensive, heavy, and exceedingly hard on the shifting system and gearcase (when not designed for the loads imposed by the SS prop).
...A runabout designed for 40 mph, or less, will gain little from a stainless prop.
The number of vessels that will NOT benefit from a stainless prop is legion, in fact.
For the high speed bass boater, river racer, or out andout power professional, however, they are the way to go."
- John Fleming, from "Complete Guide To Outboard Engines"
Sent from my LGL31L using Tapatalk
Society is meaningless without good plumbing.
dahut
SS PROP VS ALUMINUM
Post by dahut »
How much set-up adjustment have you done? With all the good you're getting already, a very minor change might do the trick.
DaleH
5
SS PROP VS ALUMINUM
Post by DaleH »
dahut wrote:"A runabout designed for 40 mph, or less, will gain little from a stainless prop."
I'd agree with that 100%!
But check out the new 4-blade 'chopper' style (see picture below) aluminum props by Turning Point ... offering 'SS performance at an aluminum blade price', says their ads. I believe it, as just bought one and love it, gives 'sit pinning' acceleration at all aspects of the RPM range!
$100 or less delivered ... that one shown is on a 60hp motor.
#4 Procraft SV14
dahut
SS PROP VS ALUMINUM
Post by dahut »
To be honest, I'm no propeller rocket scientist. I do know there are a zillion variables, though.
Your prop looks cool, fer sure. It's great that it worked out for you.
It might be the OP needs a new prop.
Or maybe not.
Considering the downsides of SS, and the fact that so much is working right with his current one, well, I wonder.
Do dealers give loaner props, if you're buying from them?
scoobeb
SS PROP VS ALUMINUM
Post by scoobeb »
The prop on it now is in decent condition, no dings or barely any missing paint off of it. I have a 1648 flat bottom alumacraft jon boat if that helps so it doesn't take much to get it going. It gets good acceleration from the get go but I was wondering what the ss prop would do for it. I'm sure if I adjusted the height of the outboard a bit higher on the transom I could gain very,very minimal extra speed,a mph or possibly 2 at best due to eliminating all drag but I rather have it sitting on the transom for more of safety reasons, like the motor coming up,etc. The risk of lifting it is not worth the reward to me so I'm going a couple different routes,1 is going to a newer type of aluminum prop if maybe a cupped prop or something else that could help this boat get on plane just a hair faster. 2nd is I am in time going to buy a brand new advanced 25hp carb for it. I called a certain place who sells then for a great price and mercury is replacing the original 25hp carb with a better designed carb for overall performance and at the same price,so going from the 20 to 25hp carb would be a monster difference. I should gain at minimum a couple to possibly 5mph at wot and I should gain a good significant amount of extra torque out of the hole if everything goes according to plan. So maybe just a nice newer prop with the carb is the way to go. Best part is the carb takes literally minutes to take off and put on. So is a Solas aluminum prop and a turning point prop just as good or is one better than the other? I'm always willing to listen to any suggestions so shoot if have any. I do know that the way it is now is satisfactory but I know I can at least bust out a bit more torque and keep the same wot speed which is awesome to start with. This engine has just rediculous and insane power for a 24yr old merc. I can only imagine what a new good prop with the carb change would do. Ok,sitting back waiting on any info you guys may bring,thanks. Sorry,didn't mean to get all hyped up,I'm just excited about this outboard because it so far has exceeded all expectations and I want to get every ounce of power out of her I can. Ok,thanks.
dahut
SS PROP VS ALUMINUM
Post by dahut »
Have you asked a dealer to loan you different props to try? Or a buy-swap plan?
Does anyone even do that?
If you're buying, and not a time waster, maybe some will let you test 'em out first?
You sound like you know what you're doing, so maybe that's a possibility to further your cause.
onthewater102
5
SS PROP VS ALUMINUM
Post by onthewater102 »
When I went looking for a SS prop for my mariner (same size 2-stroke) the shop told me the stainless is only a benefit on large motors with a lot of torque that have enough impulse energy to cause the prop to flex - but any small outboard is not going to put out that kind of power & the only other benefit is the durability.
My issue was different - my prop was running very inefficiently according to the tach (approaching redline) and the GPS speed (far too slow for the size of the boat) - I ended up needing to have a cup applied to the edges of the blade and that fixed my issues. Cupping the prop gives it more bite in the water and has the effect of slowing it down.
Before you start playing with props though get yourself a simple induction tach so you know where your RPMs are at with your current prop - it will give you an idea as to what changes you can make that will be safe for your motor.
:-) on a separate note I highly recommend the 25hp carb swap - so simple, affordable and so noticeable. I sourced mine from a newer Marathon series (mid-late 90's) 25hp through https://www.northernoutboard.com for $100 a year ago and it's an exact fit for my old '84 (early production of the '86-'90 models) - unbolt the old bolt on the new - couldn't be simpler. Here's a side-by-side comparison of the two - see how restricted the original carb throat is on the 20hp model on the left?
2002 Alumacraft 1436LT w/ 1984 Mariner Tiller Converted to Remote & 55# Minn Kota Terrova 12v (removable)
dahut
SS PROP VS ALUMINUM
Post by dahut »
Essentially what I alluded to in Mr. Flemings quote above.
But Mt. Everest is there to be climbed...
That really is a massive difference in carb throats! Wow!
RiverBottomOutdoors
SS PROP VS ALUMINUM
Post by RiverBottomOutdoors »
I've always been told that SS is more durable which makes it hard on gear case and shaft. Double edged sword.
dahut
SS PROP VS ALUMINUM
Post by dahut »
It's much heavier, too.
So every fast start ("outta the hole") puts a lot of inertia stress on the gearcase, and power head, trying to get that mass of metal going.
It also puts a lot of extra wear on the shifting dogs and gears each time you clunk that big chunk of metal in and out of gear.
And as you note, it'll take all the slamming into rocks and logs you can give it... but the gear case maybe can't.
The best way I can describe it is the SS prop has a limited use envelope where most users are concerned - but it is fashionable and very shiny.
scoobeb
SS PROP VS ALUMINUM
Post by scoobeb »
I will stick to an aluminum prop for sure,makes allot of sense to swap the carbs out though. I'm telling you from experience now that I have never ran a 20hp 2 stroke with the power this motor has,I mean it gets it. I have a 02 25hp 2 stroke mercury I'm running tomorrow morning to compare the hole shot and wot speed test. I bet the 20 Beats the 25. I have ran plenty of the late 90s to early 2000s models with the red decals and they were powerful but not like this 93 I have. My 93 20hp moved over 1000lbs of weight with ease 28.5+mph depending on wind and how flat or rough it is. I even hit near 30 a few times. With just me it hit near 30mph and that is with the standard 20hp carb, is that insane or what???? I think that is insane imo anyways,lol. I can't imagine what a carb swap would be like,wow is all I can say and excitement like crazy,I feel like a kid in a candy store, ha. My 24 yr old merc is like brand new to,low hrs,less than 30. The 02 I'm running tomorrow morning has,you ready for this,less than 3hrs,not one full tank of double oil for break in has even been ran through it yet. No matter what though I love this 93 style merc with the skinnier tiller handle and the sleek cowling design. I can't ever justify ever getting rid of it for any reason other than saving on gas. The only other motor I would put on my boat is a 20hp 4stroke suzuki or possibly a 25hp suzuki but I love how light the 20 is. I know I would lose some top end but the torque the 20hp suzuki makes is incredible for a 4stroke. It burns near no gas per hr and it will still push my 1648 near 26 to 29mph depending on weather. The suzuki is the closest thing to 2 stroke power in the portable range I have ever found. Just a sick motor and so technologically advanced for its time. So for now I will keep it until I get real world numbers on gas consumption compared to the suzuki. I will order a new aluminum 13 pitch Solas prop for my merc and in the fall my new carb. Thanks to everyone who is chiming in.
dahut
SS PROP VS ALUMINUM
Post by dahut »
Big difference what a well tuned, properly set up engine will do.
When you consider that the 2-stroke has twice the RPM capacity of the 4-stroke... I mean really think about that - it shouldn't be a surprise that it feels like a screamer.
Getting it peak tuned and then set-up right in the boats - well, that's the whole thing.
It sounds like you got it together; the stars are all aligned.
Congratulations!
beagler1
3
SS PROP VS ALUMINUM
Post by beagler1 »
How does your cav plate sit level with such a small transom?
Sent from Mossy Oak Swamp Bottom
Florida Outdoors Hunting & Fishing Forums
Http://www.FOHAF.com
onthewater102
5
SS PROP VS ALUMINUM
That's a little insane that you get those speeds out of a 1648 with the 20hp...I barely get 28 with my 1436 and just me in it. I did all my decking out of lightweight fiberglass & with the motor & TM removed my brother and I can still pick my boat up & carry it, so I know it's not that heavy. Do you have any decking in the 1648 or is it a bare hull? Also, were you the first owner of the motor or is it possible you've got the 25hp carb already courtesy of a prior owner? I gave you the pics of the two carbs - if you're certain you've got the 20hp I think I've got some more tuning to do, though I don't see how b/c it runs beautifully from idle right up to WOT even in the dead of winter.
