CAUTION - using Boiled Linseed Oil or BLO - FIRE danger!
- Donor
- 7
See: https://www.naturalhandyman.com/iip/inf ... mbust.html
Be AWARE that when rags soaked w/ boiled linseed oil can start a fire due to spontaneous combustion. This ain't bull crap or an urban legend ...
I want to be sure that everyone knows this, as a good friend's garage and 1/3rd of his house burnt down in a fire started by BLO-soaked rags. Some of you probably know him, as he is a fishing guide in the MD area of the Ch-Bay and posts on their Tidal Forums.
FWIW another boater I know, who finishes fine furniture, leaves such rags lying way out on his back lawn to dry or air out and then he stores them for re-use in a closed/sealed steel container.
I see MANY here recommending it ... but no one cautioning about the potential FIRE issue ...
18' Lund viewtopic.php?f=21&t=36583
25' Parker https://www.classicparker.com/phpBB3/vi ... p?f=15&t=6
16' V Rebuild viewtopic.php?f=21&t=36465
16' Starcraft NEW Transom Skins viewtopic.php?f=3&t=37548
15’ Starcraft NEW Transom viewtopic.php?f=3&t=47405&p=473317
- Donor
- 8
CAUTION - using Boiled Linseed Oil or BLO - FIRE dangers
good point Dale !!!
and yes the spontanious combustion is a very real concern.
I guess I was only "assuming" that people using ANY kind
of volatile substance reads, understands and follows the instructions
and SAFETY precautions for the products they use.
Now that cold weather is forcing many hobbyists indoors to do their
projects, this issue should be a genuine concern and taken seriously.
excellent information !!
https://www.tinboats.net/how-to-build-a-transom/
https://www.tinboats.net/varnish-vs-polyurethane/
All about Primers = https://www.tinboats.net/primer-and-paint-basics/
Paint, Thinners and Applications = https://www.paintingforpainters.com/
I have a metal garbage can with a lid I keep outside that I throw all of the towels and rags I use into.
- Donor
- 14
Remember the fire triangle. All you need is heat, oxygen and fuel and you have the ingredients to make fire.
A couple of years ago, my son found a pile of very hot paint rags in his garage. He got them outside before anything bad happened. The warning is TRUE!
DO YOUR PART, STAY APART!
- 5
We were taught this very lesson in shop class by Mr. Pagnetti in the early 70's, all rags went into a metal can with n auto close metal lid. Good looking out!
- 5
lckstckn2smknbrls wrote:I have a metal garbage can with a lid I keep outside that I throw all of the towels and rags I use into.
Yes, this is a best practice. I have a small metal can with a lid outside. Final resting place for all used rags.
Have Rod - Will Fish
- 7
Years ago when taking pictures and getting them developed was the norm my wife and I had recently returned from an extended vacation. I had just returned from the 1 hour photo processing place as she was finishing up some laundry. Without knowing she placed a pile of clothes fresh from the dryer on the bag of photos that I had laid on the bed. As she stood there folding laundry the pile exploded into flames. We ended up losing the mobile home and all the contents. We got ourselves and both kids out safely but in just a matter of minutes it all went up in smoke. Turns out that the chemicals from the photo processing and the heat of the warm laundry was enough.
Sometimes it is the people no one imagines anything of who do the things that no one can imagine.
( Alan Turing )
( Alan Turing )
Wow.... Thanks for the warning. Glad you all got out OK. Guess you just never know, do you?
A hundred years ago, it seems, I used to enlarge, develop and print my own FILM. Never knew the chemicals were that volatile.
- 5
We had this happen at work - did quite a bit of damage to our electrical repair shop.
- 5
When BLO cures it generates an exothermic chemical reaction, meaning it generates heat.
So you don't want a pile of rags, or a spot where heat can build up.
But mostly I just wanted to use a 50-cent word pop taught me a couple decades ago.
Well done. Smart pop. Got any more ! Ha Ha richg99
- 9
To All,
Fwiw, remember the following bit of rhyme/drivel, when dealing with linseed oil as a finish: "Boiled forms a skin; raw oil soaks right in."
Not only is RAW Linseed Oil SAFER to use & won't spontaneously catch fire but it is a BETTER finish for wood from most every standpoint. = FACT.
yours, satx
yours, satx
Resistance to tyrants is obedience to Almighty God.
Thomas Jefferson, 1803
Yep, I think mineral spirits soaked rags will do it too.
- 7
Had a trash bag in my kitchen catch on fire internally for a while. Thankfully we noticed and got it outside quickly
Sent from my SAMSUNG-SM-G870A using Tapatalk
