Here are a boat speed and prop slip calculator if anyone is interested:
Theoretical Hull Speed = ( Prop Pitch X RPM ) / ( LU Gear Ratio X Constant of 1056 )
Prop Slip = ( Theo. Speed - Actual Speed ) / ( Theo. Speed )
I have found the speed one pretty accurate with small open v-hull skiffs. But where a lot of your guys' boats have extensive flooring, decking, and compartments ... I'd expect lower actual speeds due to the actual weight carried. Also note a jon boat will have more wetted surface on the running hull and will be slower.
Boat Speed and Prop Slip calculators
- Donor
- 7
18' Lund viewtopic.php?f=21&t=36583
25' Parker https://www.classicparker.com/phpBB3/vi ... p?f=15&t=6
16' V Rebuild viewtopic.php?f=21&t=36465
16' Starcraft NEW Transom Skins viewtopic.php?f=3&t=37548
15’ Starcraft NEW Transom viewtopic.php?f=3&t=47405&p=473317
- 5
Thanks man. I'll try and figure it out. Going to raise the motor up a bit and play with trim this weekend. I just figure I had a fiberglass glasstream bass boat years ago with a 70 that ran 42. This boat weighs half as much it should scoot! Hopefully I can get it dialed. I'll post up as I experiment. Hopefully put a tach on soon as well.
Sent from my HTC One M9 using Tapatalk
- 5
Knowing ones LU gear ration is key to this.
- 8
1991 18' Valco Bayrunner Evenrude 48 SPL
Arizona
Arizona
- 1
Thanks For the formula. but i don't fully understand how to use it correctly for calculations
