riverrat717
I recently added a Rockproof jet foot, and I'm getting alot of spray from it. Any one else have this issue?
handyandy said:try raising the motor a little they hang a little lower than regular intakes I have it's tough but like a block I wish back when I bought mine wooldridge had their poly intake I would have saved my money to put towards that.
overboard said:No expert here, but I would measure where the foot is in relation to the bottom of the transom and see if it does sit lower than the one you had on, or just put the intakes side by side and compare. If the new one is longer then you may have to raise the motor. If the boat runs good, and the foot is slightly lower and didn't affect performance, maybe you could install a splash guard that goes on the transom and extends out to the foot to resolve the spray issue, that may be an option over re drilling the transom holes. Also depending how much you need to raise the motor, the mounting holes on the motor may be able to be elongated slightly.
I have two Tracker GRIZZLY'S, I think if I ran into what you did I would just get the holes in the transom welded and go from there, in my case only two mounting holes are in the transom, the other two are in a riser.
It seems strange that the replacement foot would be a different dimension than the original intake, seems like that could be a problem for guys who already have their jets mounted and could run into the same problem as you.
Did you call Wooldridge and see what they have to say, there may be other options and that's the first thing I would do!
Of course the other option would be to stick with the stock foot, problem solved!
Maybe an adjustable jack plate also!
GOOD LUCK!
