I redid my previous build due to some support framing rot. It's not a huge difference than the old one. I just did some things differently as well as added some things. Not as fancy as some of the builds on here, but it works for me.
Previous Build - https://www.tinboats.net/forum/viewtopic.php?t=18934
1. The deck was raised up a little to make it almost level to the front. The previous build was more level with the benches. It turned out just a hair higher than I had wanted. But it will work. I also added some vents on the deck.
2. The hatches are smaller and I also added a hatch just for the trolling motor battery.
3. I made a non-slip pad using a rubber mat and plywood for the bottom of the TM pedal. Works great.
4. New switch box with a fuse block inside, instead of the pre-made switch panel I had before. More control over each circuit and easier to add on if needed. The wiring is also a lot more neat than before. I also added a digital voltmeter that tells me the voltage of each battery.
5. Added 12V and USB ports in middle of the boat. Will be nice to have for my portable livewell/handheld spotlight and to charge my phone.
6. Charger is in a better location and now I don't have to open the hatch to charge the batteries. I added an AC port. I also added a couple of small LED light strips to the interior as well.
7. Added a RAM mount to the front and now I'm using separate red/green NAV lights for better visibility. The RAM mount ball is for mounting an LED lightbar. Will be nice to have for flathead fishing at night in those narrow sloughs. I always wanted to have some sort of headlights, but wanted something that was easily removable.
1648 Crestliner Mod V REDO
Tracker PT 190 TX TE
1648 Crestliner Mod V - SOLD
- 8
Really like the RAM mount for the LED bar & the rubber mat anti-skid backing for the TM pedal. Definitely copying you on both of those!
1985 Bass Tracker III
2002 Alumacraft 1436LT (SOLD)
Just tried out the lightbar last night in some back water sloughs and I must say that I was blown away. I could see everything in front of me very well. Highly recommended.
