For running in my small (12' to 14') tins, home made livewells. My company uses a ton of barrels like this, so I get my pick from 20 to 35 to 50 gallon 'poly' barrels. Add a few fittings for inlet and outlet ... and presto ... instant livewell.
Add a pump and inlet hose, where the pump direct connects to a battery, with a waterproof in-line switch, and off you go. A simple strap of bungee cord helps keep the lid closed to avoid losing too much water in waves/wakes.
TIP - I find blue colored barrels keep the saltwater baits (mackerel or pogies) less stressed. Plus I add a simple 90-degree elbow to the inlet side to circulate the water in a revolving manner, not just straight into the side of the barrel.
Homemade livewell
- Donor
- 7
Homemade livewell
18' Lund viewtopic.php?f=21&t=36583
25' Parker https://www.classicparker.com/phpBB3/vi ... p?f=15&t=6
16' V Rebuild viewtopic.php?f=21&t=36465
16' Starcraft NEW Transom Skins viewtopic.php?f=3&t=37548
15’ Starcraft NEW Transom viewtopic.php?f=3&t=47405&p=473317
