New Transom – 1976 Starcraft ‘Holiday 15’ Model
- Donor
- 7
Raka will be ~1/2 the price of West Systems epoxy.
18' Lund viewtopic.php?f=21&t=36583
25' Parker https://www.classicparker.com/phpBB3/vi ... p?f=15&t=6
16' V Rebuild viewtopic.php?f=21&t=36465
16' Starcraft NEW Transom Skins viewtopic.php?f=3&t=37548
15’ Starcraft NEW Transom viewtopic.php?f=3&t=47405&p=473317
- 1
I see you used a piece of plastic on the back of the transom, between aluminum hull and the motor. Is that anything special? I had the same plywood backer as this boat, which is toast... and curious what you used there. Thanks for info
1978 Starcraft SUS 16 O/B
Powered by:
1993 Johnson 48 SPL - 2 Stroke 48hp Model: J48ESLETE
1998 Honda 8hp - 4 stroke Model: BF8A
Minn Kota Maxxum 80lb electric TM
Boat build log
Powered by:
Boat build log
- Donor
- 7
I had a sheet of HDPE, high density polyethylene ... think 'cutting board' plastic. Try to find a big cutting board at a discount store or call a plastics distributor near you.silentbravo wrote: ↑14 Mar 2021, 18:57 I see you used a piece of plastic on the back of the transom, between aluminum hull and the motor. Is that anything special? I had the same plywood backer as this boat, which is toast... and curious what you used there. Thanks for info
