I no longer need the pictured guide posts. The PVC part is about 30". The total height from the bottom of the bracket is about 40" - 42". Each leg of the brackets is about 16". I also have the mounting plates and U-bolts (not pictured).
You will notice the one on the right had some heat applied. Don't ask! Haha.
All I ask is that you be an existing TB member and pay the postage. Or, if you are near the Concord area we can arrange a pick-up.
Total package will weigh about 15 pounds. Box size will be about 36"x18"x4" (or as close to that as I can find). I'm in zip 94517. If you are interested please calculate mailing cost to your location to make sure it is worth it you.
First come, etc.
Thanks.
CE Smith Guide Posts
- 5
Have Rod - Will Fish
- 1
Oh, I need a set of these...wish you were closer. UPS is having a hard time figuring out the postage....I'll see what I can get from Fedex. I'm at 30316
- Donor
- 7
If Hardwaregrrl backs out, I’d take the posts.
Consider shipping them WITHOUT the PVC, as that can be locally sourced for cheap. It is the length of the package that’ll skyrocket the shipping co$t.
18' Lund viewtopic.php?f=21&t=36583
25' Parker https://www.classicparker.com/phpBB3/vi ... p?f=15&t=6
16' V Rebuild viewtopic.php?f=21&t=36465
16' Starcraft NEW Transom Skins viewtopic.php?f=3&t=37548
15’ Starcraft NEW Transom viewtopic.php?f=3&t=47405&p=473317
- 5
OK, let me know what you decide. Dale's suggestion about skipping the PVC makes a lot of sense.hardwaregrrl wrote: ↑25 Jul 2020, 22:55 Oh, I need a set of these...wish you were closer. UPS is having a hard time figuring out the postage....I'll see what I can get from Fedex. I'm at 30316
