Long term small engine storage
Anything you do off the water can go here. Racing, Modeling, collecting? Talk about it here.
CedarRiverScooter
Post by CedarRiverScooter »
I am going to put my generator in a coma, hopefully for years.
Do you guys have any best practices for how to prevent the carb from getting gummed up during long term storage? I don't want to have to start it just to freshen gas in the bowl. I know to run it dry. Seems to me gas is still in the jets though.
Would filling it with seafoam be good too?
ktoelke54
5
Re: Long term small engine storage
Post by ktoelke54 »
I think that running it dry clears the fuel from the jets. This has worked fine for me over the years. There might be a little fuel left in the bottom of the bowel. Lots of carb bowls have a drain on the bottom. Also, when running it dry I feather the choke when it begins to sputter. I think this helps get the last bit of fuel out. Not a bad idea to fog piston also.
DaleH
Post by DaleH »
DEFINITELY fog the motor!
CedarRiverScooter
Will fog.
I put non-eth with stabil thru it. Then ran it dry. Then wiped out the remnants in the tank (metal tank, how old school is that!). Then took off the bowl & wiped that out too.
It may be 10 years before I need it again! That would be fine with me. Power outages not fun.
maintenanceguy
3
Post by maintenanceguy »
ktoelke54 wrote: 19 Aug 2020, 09:43 I think that running it dry clears the fuel from the jets. This has worked fine for me over the years. There might be a little fuel left in the bottom of the bowel. Lots of carb bowls have a drain on the bottom. Also, when running it dry I feather the choke when it begins to sputter. I think this helps get the last bit of fuel out. Not a bad idea to fog piston also.
This is what I do. Evaporating gas leaves a sticky varnish behind. I shut off the fuel and run the motor until it dies to get the fuel out of the carb for storage.
-Ryan
