Trailer Setup Questions
Trailer related issues and discussion goes here.
gauntletkl
Post by gauntletkl »
Hey All,
Just got my first boat and trailer. 14 foot jon boat and a used loadrite trailer.
I am wondering how to properly adjust the trailer to fit the boat. Read a few things online but hoping to get some answers on the below.
- End of bunks should line up with transom?
- Should the bunks be setup closer to the edge of the boat or closer to center? Right now they are near the edge
- Should the jon boat sit above the fenders or between them?
- Should the bunks be adjusted to the lowest setting? The highest setting is above the fenders
- Should the pivot point at the top of the bunk be loose or tightened down tight?
- The trailer has a center roller, should this be adjusted to the lowest setting? Right now it seems like that most of weight is resting on the roller
- Winch roller should sit above bow eye?
Thanks for the help.
JL8Jeff
Post by JL8Jeff »
The bunks look a little short to me. I have 8' bunks on my trailer for my 1652. You want the bunks to reach all the way back to the stern and maybe a little past it to make sure there is full support. The height looks good (but you may need to raise it if you plan on running a prop motor) and I would try to align the bunks right along the strakes, it will help make it easier to load and be self centering. Once the boat is lined up on the bunks and sitting flush on the bunks, I would tighten the pivot point on the bunks so they can't move. The center roller will take a lot of the front weight of the boat so that's one reason I would go with longer bunks. If you have room to put the boat between the fenders then you can lower it and make it easier to load/unload in less water but it might depend on your motor again. I have the winch roller above the eye so the winch line can run under the roller and pull the boat down on the trailer. My boat is a jet tunnel with a short shaft jet which sits up so I have my trailer set up with the boat as low as possible and I don't have to tilt the motor. I have my bunks moved in so they are between the strakes. I actually moved my center roller forward of the junction where the beams come together since these pictures were taken.
2001 Lowe Roughneck 1652 VT with Merc 60/45 jet 2 stroke
gauntletkl
thanks for the reply. When you mean align the bunks along the strakes, are you saying between the 2 interior ones? Any issues with the roller and bunks all being in the center of the trailer/boat?
lckstckn2smknbrls
Post by lckstckn2smknbrls »
Leave the two bunks you have now where they are and add two more longer bunks where the red arrow is.
Do away with the roller and add a cross bunk. I can't see what you have for a bow stop but a carpeted 2x4 work great.
JL8Jeff
Post by JL8Jeff »
gauntletkl wrote: 19 Aug 2021, 17:21 thanks for the reply. When you mean align the bunks along the strakes, are you saying between the 2 interior ones? Any issues with the roller and bunks all being in the center of the trailer/boat?
On my boat I have the bunks where you have the red lines. Mine is a 1652 so it would depend on how wide your 14' is if you want to go in that far with the bunks. I think you're good with where they are now, I would just go with longer bunks. But it looks like the front of your boat is too high and it's not actually resting on the front of the bunks (I think I can see a shadow in your picture showing the space between the boat and front of the bunks). So you may want to lower the center roller or raise the front of the bunks to get the boat sitting on them flush.
gauntletkl
thanks for the help. Does it matter if the boat is sitting between the fenders or above them? Thinking about clearance when loading, but I am imagining that between the fenders may help with aligning.
JL8Jeff
Post by JL8Jeff »
I don't think it matters, lower between the fenders might make it easier to load/unload in shallow water.
