1972 Alumacraft F-9 Lake Master
MN Fisher
1
Post by MN Fisher »
Kismet wrote: 24 May 2022, 14:59 Take your time getting well, but for sure, get well.
The boat, motor, and soon-to-be crew's quarters will wait for you.
Thanks - and yes, I'm not doing too much and resting when I start feeling 'worse'. I think I'm on the back-side of it though - I feel loads better today than I did just 3-4 days ago. I did take a couple days off of the work...reason I'm behind (more).
FuzzyGrub
Post by FuzzyGrub »
If our projects had to hold to a schedule, they'd need much more re-vamping/fixing. ;)
Project: 1995 1648 DMI/1998 25HP Merc:
1967 Starcraft 14' Mariner V/1987 Nissan 40C
1997 Bayliner Capri 2050/350 4brl Vortec Mercruiser
JohnS https://www.joefishin.com/
MN Fisher
1
Post by MN Fisher »
Way it's looking - probably early next week and I'll be putting the finishing touches on this.
Hatch-lids for casting deck are currently being Varathaned before carpeting
Transition piece between casting deck and TM deck is currently being sealed before painting
TM battery is ordered, should arrive Friday and I'll get that in
TM support just needs to be bolted down
Some wiring to run between the ends and the connections for the sonar and bow USB ports
Finish painting the port side of the outer hull - starboard side is done and ready for decals.
Ya, it's getting close.
FuzzyGrub
Post by FuzzyGrub »
Almost there! Looks like a decked out fishing boat, now. :)
MN Fisher
1
Post by MN Fisher »
So close now - need to
Finish and install the hatches
Finish painting the port-outer hull
Apply decals
A bit of electrical work - install a standard stop switch and an ECOS on the motor
Buy a but-seat for the front and a starting battery.
That's it...I'm looking at having it done by the end of the week.
Perfect!
Please use our Amazon Affiliate link. It costs you nothing and sends a few cents to the site.
Amazon Link!
MN Fisher
1
Post by MN Fisher »
Just have to do a little touch-up on the paint, install the starting battery (going tomorrow morn to buy it), and she's done.
Looking at Monday for her maiden voyage...I don't go on Tonka on the weekend - especially a nice weekend like we're suppose to have...all the crazies are out.
I'll be posting a 'sales pitch' type vid probably Sunday going over all the features.
MN Fisher
1
Post by MN Fisher »
Teaser - shooting the full vid in a bit.
Quick View
Kismet
Post by Kismet »
MN? Really handsome job; congratulations on your work and finishing touches.
I'm curious about the center of gravity when in the water. I presume the weight of the mods will contribute to greater stability, but that front seat still seems high. I think the F-9 is 60 inches wide.
I've been out in chop and wind that has had me whispering to the water gods "just let me get to the dock." [-o<
Beautiful work. Take very good care of yourself.
=D>
Kis
Enjoy every sandwich
1955 Alumacraft Model A
https://www.tinboats.net/forum/viewtopi ... 08&start=0
1959 Alumacraft Model F
https://www.tinboats.net/forum/viewtopi ... =3&t=25386
1980 Alumacraft Model F7, 1955-56? Johnson 10hp
viewtopic.php?f=4&t=35326
1956 Alumacraft Model RB
https://www.tinboats.net/forum/viewtopi ... =3&t=39249
MN Fisher
1
Post by MN Fisher »
Kismet wrote: 26 Jun 2022, 11:16 MN? Really handsome job; congratulations on your work and finishing touches.
=D>
Thanks, Kismet, for the nice words
The butt-seat isn't to sit on really, it's just something to add stability as you use it like a tripod - two legs are your legs, the third leg is the seat...so yes, it's a little higher than a sit-in seat.
Far as the center of gravity - from my calculations, it's still over 100lbs under the max-capacity of the boat and the max beam is 64" with the transom width indeed being 60". It's known as a very stable hull - and it's still the base hull used for the V-14...so the F-9 is the V-14's father.
I've been in boats that are narrower in heavy waves - my old Duo runabout was a 56" beam, 52" transom with a 40hp, and I cut through 3' waves one time on the way back to the launch when the wind came up fast. I'm not to worried about the F-9 in moderate weather.
Tomorrow is the 'test run'...it's predicted to be a relatively calm day (5-10mph winds), and the place I'm launching is a small bay near my house, so I'm not going to be too far from shore at any point.
The yellow line on the pic below is .34 miles long.
MN Fisher
1
Post by MN Fisher »
And the final overview video (took me 3 takes and it's still not 100%, but I got other things I need to do)
Lake Master Bass Boat Part 10: Final Product
LDUBS
6
Post by LDUBS »
Well done MN Fisher. I look forward to seeing some on the water footage from those cameras.
Have Rod - Will Fish
MN Fisher
1
Post by MN Fisher »
Camera footage downloading to my computer now - be a bit before it's all edited.
Came across a couple minor issues:
1: Direction indicator on the TM is reversed - the arrow points sternward when moving forward.
2: Livewell fill isn't working...pump engages, inlet is well under water, but no water going into the tank.
Luckily for that second - I take the gas tank out and the four screws holding the fore and aft cockpit panels in - all four panels come out, then the floor just lifts out...so it's easy to get at the entire run of plumbing.
