jon boat floor help
electricblue
jon boat floor help
Post by electricblue »
I just bought a Seaark 1652 and want to do a floor. Everything I have seen on youtube has a flat bottom. On mine when you get to the front it rises up. Id like to keep the floor flat and as low as possible. I dont want to jack the back up and lose all that space. Was thinking about using 2 sheets of thinner plywood to have it bow up in the front. Does anybody have a solution or come across this?
eeshaw
2
jon boat floor help
Post by eeshaw »
You can use .100 aluminum. It should be flexible enough to allow some rise. You can back it up on the under side with some of that 2 inch pink foam panels that the box stores sell for insulation.
electricblue
jon boat floor help
I priced 1/8 aluminum it was 650$. Gonna have to stick to wood for now.
DaleH
jon boat floor help
Post by DaleH »
electricblue wrote: 01 Oct 2021, 08:31I priced 1/8 aluminum it was 650$. Gonna have to stick to wood for now.
You don't need that thick, as I bought sheets of 5052 alloy @ 0.086" thick for $86 per panel, but was a few years ago. For what you're doing I'd be more inclined to use a sheet of Luan soaked out in wetting/penetrating epoxy. And I'd cover it w/ marine vinyl, but then I prefer vinyl to carpet, as lighter and lasts 4-5 times longer.
electricblue
jon boat floor help
Material prices are out of wack right now .080 4x8 is $400
LDUBS
5
jon boat floor help
Post by LDUBS »
1/4, 3/8, or 1/2 exterior ply. Coat in epoxy like DaleH says above. Under $50 per sheet.
Have Rod - Will Fish
JL8Jeff
jon boat floor help
Post by JL8Jeff »
Wow, with the price of the aluminum that high, I think I would wait until it comes back down before doing anything. The weight of the plywood probably isn't worth it. My Lowe had the floor option which is nice (as well as a center console). It does have the bend to it as you get farther to the front. The big issue with the aluminum floor was that it got too hot (my boat sits out in the sun at a dock) so I had to put some vinyl flooring down to be able to walk on it barefoot.
2001 Lowe Roughneck 1652 VT with Merc 60/45 jet 2 stroke
eeshaw
2
jon boat floor help
Post by eeshaw »
wow, I had no idea cost for aluminum had gotten that high. I'd wait till they come back down to something more sane.
old_fart
1
jon boat floor help
Post by old_fart »
electricblue wrote: 01 Oct 2021, 08:31 I priced 1/8 aluminum it was 650$. Gonna have to stick to wood for now.
Thoughts on polyethylene foam?
About $150 to get several 4x4 sheets to fill & cover between middle & rear seat
(and if you remember that "Candid Camera" episode with the
soft foam under the carpet, you just dated yourself :-)
https://www.foambymail.com/XPE2/cross-l ... m-2lb.html
-W
lckstckn2smknbrls
jon boat floor help
Post by lckstckn2smknbrls »
You can get the pink or blue foam at most big box hardware stores.
old_fart
1
jon boat floor help
Post by old_fart »
lckstckn2smknbrls wrote: 05 Oct 2021, 18:50 You can get the pink or blue foam at most big box hardware stores.
Rigid polystyrene (i.e. insulation) won't hold up to being walked on.
The polyethylene foam is flexible, so it's like walking on a hard cushion (easier on bare feet).
And it doesn't rattle like composite deck boards would on a Sunday afternoon.
drewestin
jon boat floor help
Post by drewestin »
Nice boat. Congratulations on your new purchase.
BAY BEAGLE
jon boat floor help
Post by BAY BEAGLE »
.190 - 4 ft x 10 ft #5052 aluminum sheet - $490 ..... 2022 today's price
- A FLATLANDER -
Tin Ark
1
jon boat floor help
Post by Tin Ark »
Don’t skimp you will regret it. Rebuilding an 1872 SeaArk now. Check out my thread, I’m documenting process with video. It’s in this sub forum.
