Bear trailer issue
Trailer related issues and discussion goes here.
the hammer
15
Bear trailer issue
Post by the hammer »
I tried lifting the tongue off the hitch by raising the trailer jack but I don’t know if that would really prove anything.
MrGiggles
4
Bear trailer issue
Post by MrGiggles »
Doesn't look like a locknut to me.. Should have a Stover/Nyloc on it, even if it has a lock washer.
the hammer
15
Bear trailer issue
MrGiggles wrote: 13 Oct 2021, 16:46 Doesn't look like a locknut to me.. Should have a Stover/Nyloc on it, even if it has a lock washer.
Just a regular nut.
MN Fisher
Bear trailer issue
Post by MN Fisher »
the hammer wrote: 13 Oct 2021, 17:29
Just a regular nut.
That's probably the issue - unless it's a lock-nut or at least has a lock washer, the vibration of carting it down the road will loosen the nut and could possibly cause you to lose the trailer on a bump.
Just go with a lock-nut...solves a lot of the issues.
Note: While the boat I picked up had a lock washer on the coupler mechanism, I replaced the regular nut and lock washer with a lock-nut.
LDUBS
5
Bear trailer issue
Post by LDUBS »
the hammer wrote: 13 Oct 2021, 12:43 I tried lifting the tongue off the hitch by raising the trailer jack but I don’t know if that would really prove anything.
Oops!
Have Rod - Will Fish
LDUBS
5
Bear trailer issue
Post by LDUBS »
I do the same thing with the travel trailer. Just to make sure. Actually, I have to do that in order to hook up the weight distribution bars, but it seems like a good test to me.
JL8Jeff
Bear trailer issue
Post by JL8Jeff »
My coupler has a spring and a nylock lock nut. I actually have to remove the coupler from the trailer to fit the boat in the garage at an angle and be able to close the door. Does your coupler have a spring under that metal plate?
2001 Lowe Roughneck 1652 VT with Merc 60/45 jet 2 stroke
the hammer
15
Bear trailer issue
JL8Jeff wrote: 14 Oct 2021, 10:24 My coupler has a spring and a nylock lock nut. I actually have to remove the coupler from the trailer to fit the boat in the garage at an angle and be able to close the door. Does your coupler have a spring under that metal plate?
Yes.
lckstckn2smknbrls
Bear trailer issue
Post by lckstckn2smknbrls »
The metal plate under the nut has raised sides that keep the nut from backing off.
the hammer
15
Bear trailer issue
I’m wondering if it might be to my advantage to make the hitch ball higher by 2” rather than hitch and trailer being level. I can’t help but think it may have helped.
LDUBS
5
Bear trailer issue
Post by LDUBS »
I don't think you would gain anything by raising the hitch. Better to keep the trailer level I think.
MN Fisher
Bear trailer issue
Post by MN Fisher »
LDUBS wrote: 18 Oct 2021, 12:45 I don't think you would gain anything by raising the hitch. Better to keep the trailer level I think.
Exactly...raising the hitch will make the ball/coupler connection 'off center'. More centered the connection, the less chance of it jumping off due to an incomplete closure of the latch.
the hammer
15
Bear trailer issue
You guys are probably right, considering how close I have it to level!
GYPSY400
Re: Bear trailer issue
Post by GYPSY400 »
If your hitch is adjusted correctly it should have some resistance when closing the lever on top. If you have to stand on it to close it it's too tight, but if it swings down easy it's too loose. I'd buy a new coupler assembly if it's not welded on the tongue, they do wear out over time.
Sent from my SM-A526W using Tapatalk
maintenanceguy
3
Bear trailer issue
Post by maintenanceguy »
replace that nut with a nylon lock-nut. At least it won't loosen on its own.
-Ryan
