Fanttik X8 APEX Tire Inflator Portable Air Compressor
Talk about anything that floats your boat (no pun intended). This is general talk about anything not related to boating/fishing.
Gimmick or worthy of consideration? Check out the youtube video......
Please use our Amazon Affiliate link. It costs you nothing and sends a few cents to the site.
Amazon Link!
silentbravo
1
Post by silentbravo »
Looks like it might work OK, but it's going to struggle on truck tires if you need to add any meaningful amount of air. Definitely won't be airing down all 4 corners for off-roading and expect to air back up with this.
Kind of handy looking for bicycle and small balls/toys though.
1978 Starcraft SUS 16 O/B
Powered by:
1993 Johnson 48 SPL - 2 Stroke 48hp Model: J48ESLETE
1998 Honda 8hp - 4 stroke Model: BF8A
Minn Kota Maxxum 80lb electric TM
Boat build log
LDUBS
5
Post by LDUBS »
Warning - might be some harrumphing and even a little grouchiness included in the following: . :)
I am skeptical that this would work as claimed on truck or RV tires or that it would last very long (keep in mind the size of the compressor pump in these little units and the volume of the tire). Instead, get a 12V plug in inflator. For footballs, basketballs, bicycle tires, use a hand pump. Because my truck has an inverter and my trailer has a generator, I have a 120V portable tire inflator.
I think if I wanted a battery operated tire inflator (which I don't), I would go with one of the mainstream tool manufacturers (like Makita).
OK, end of harrumphing.
PS: If I'm not there, Mrs Dubs has AAA roadside assistance as a backup! Lol.
Have Rod - Will Fish
