Cracked ribs in large boat questions
Xaero
I am acquiring an aluminum 1999 SeaArk 2472MV. It started its life as a rear center console then remade into a forward console striper boat at some point in its life. It's had very large bait tanks in it for years and used on almost a daily basis. The entire insides are now ripped out leaving only the original front deck and all the ribs exposed. Most of the ribs are cracked right at the side bend.
How would someone repair the ribs? Clean the cracks as good as possible and directly weld them? Weld braces over the cracks? Maybe I should just scrap this boat as it is too old?
The hull seems solid enough so it may be worth building on. I don't plan on going to crazy with the build. Add flooring, a small console, and some seating on the sides. Maybe extend the front deck again. The deck extension was not built right and has been removed. The transom looks solid although it had an outboard over its limit on it for at least two years (150hp Mercury). I was on it while it was running and didn't see any bending, etc. I dont know if there is wood inside it.
without seeing them in person, be hard to say whether or not they can be welded.
Aluminum is funny. If it's not perfectly squeaky clean, it's very very hard to get it welded properly. And when it comes to boats, getting the material clean enough is where the challenge lies. This is especially true with TIG welding, which I would suggest. MIG can be used too and successfully, but even seasoned welders tend to skimp on the cleaning process, which directly affects the weld strength.
Pics would help, but here's what I know as a welder.. any material once stressed and broken and welded, is never as strong as it was. The parent material gets diluted with the filler alloys and also the heat stresses introduced into the heat affected zone, weaken what was once strong. Sounds like this boat was likely pounded over rough water on a regular basis.
This doesn't mean you should abandon the project, just examine your usage, how much you plan on putting into it and what your expectations are before proceeding. Gussets can likely be added to strengthen the broken ribs. Tying the sides together with decks will help with the flexing. Anything you can do to increase rigidity and decrease load will greatly help longevity. Don't cheap out on the structural stuff. Have a good welder look it over and give you an opinion
Thanks for the info! I do need to get some pictures and talk to a welder I know. I know it was not pounded by waves and the previous owner did drive like a grandma most of the time. The bait tank and up to 6 passengers daily was the stress on it. I was told by a friend SeaArks crack like this a lot when a big bait tank is involved. I have not verified that statement with anyone else yet.
Looks like they already started welding in some braces over the cracks. It’s holding water really good too haha!
Looks like a good start to cover the cracks but won't lend much strength to the corner. Suggest using side gussets like crudely doodled in my pic. On the upside, its wide open and easy to access. Cleaning all the areas with a grinder with a wire wheel/cup brush will save you a bit of time on the prep work. Maybe make a template for the gussets. A shop with a CNC plasma or better yet a water jet can cut them out. Gusset doesn't need 100% weld just where it's easy to reach. 5000 series aluminum if it's available, or 3000 series. Don't use 6061.
Thanks! I will look into the gussets. It's weird how memory works. I thought the boat would be a lot more loose than what it really is. It's a rock solid thick hull. I cant make the sides move at all or the transom.
How about using rectangle pieces? We had no way to do an angle cut and the area isn’t flat. We had to bend the part and use a clamp to flatten it.
Anything is better than nothing. The more material you can get alongside the better. The top strap will give lots of strength when the side wants to flex out, but not as much when it wants to flex inward.
If you are just going to carry about 4 to 6 in unexpected rough water ? salt & fresh water ? With at least 1 or 2 WALK THRU bulkheads ? Copying a modern 24' aluminum boat layout is REQUIRED !!!!
Web posting by the DIY 16' guys is not recommended !!
What use are you planning ? Or just a quick buck to sell it ?
You do realize this boat WILL EAT up money & a good welder & lots of corner braces on the floor corners ? A FINE SAND BLASTING is a must . BEFORE any welding.
There needs to be Long Storage boxes along the sides to prevent sides from flexing a lot again.
I suspect the boat was used in salt water some time with so many bait tanks ? If so, there is a ton of salt in all the floor ribs being eaten up constantly.
You need SKILL not DIY luck on this one.
Respectfully disagree with the above post....totally fixable.(not full of pinholes is it?)
Exspensive,maybe(dont know your budget)get an estimate before diving in...we all know what BOAT stands for
Sandblasting not needed before welding, sure get it down to bare metal but any welder would do that. Maybe to save money you could do most of the prep work, grinding, have pieces(gussets)cut to fit...make sure to vacuum the dissimiliar metal filling.
Didnt notice any pinholes, did you?
Salt not a big concern if using aluminum, just try to stay away from dissimiliar metals. Flush with freshwater once and awhile,should be fine.
This is a manufacturing defect. A friend bought a brand new 1997 Sea Ark center console. It did exactly what you see within the first year. They fixed it several times, but it kept coming back. The last time they fixed it, he traded it back to the dealer for a Parker. They did something wrong with those boats.
Put side gussets on those patches, weld to the side and then tie to the top strap. Hopefully, that holds.
You are looking at a lot of work. If you aren't doing the welding, that might cost more than the boat is worth.
I hope it works out for you. one way or another
My Duracraft had some rib cracks like that. The welder welded them up…. Wasn’t that expensive. Adding decks back in will stiffen things back up too.
Did you buy the boat and then sell it again or back away from buying it?
Ive seen instances where sandblasting prevented a proper weld on aluminum.
Our TIG guy said that the abrasive gets imbedded in the surface of the aluminum and really messes with getting a good bead or any bead at all.
Next time adjust the air pressure & distance. It will allow welding. Allwelder brush clean weld areas before welding. I use a S S wheel.
