Help!! 1999 Bass Tracker Pro Team
I'm rebuilding a 1999 Bass Tracker. During the tear down process, the floor was so rotted out that it practically fell apart as I was taking it out. Does anyone have the floor measurements for the boat before carpeting? I was able to save the deck as a template but didn't think to measure the floor beforehand as this is my first boat project. I appreciate any help that anyone could give!
How large of a piece of cardboard can you get? I have only redone one boat. was very lucky to read up about saving old decking? carpet as template. But where the wood was to rotten, or I needed to fresh mod, cardboard is awesome! Lay it down, cut/ mark it!! Double Check!! use that as a template for your wood/carpet cuts!
I'd go the template route myself...
5-sheets of 3' x 4' corrugated cardboard for $32 https://www.amazon.com/dp/B01D274EBS?ps ... ct_details
The 'box' they came in gives you two more for a total of 7 sheets.
That's what I'm using for templates in my build.
Current project:
1972 Alumacraft F-9 Lake Master
Thanks! Hadn't thought of the cardboard route!
There is a township recycling center not far from me. When I need big pieces of cardboard I check there.
Good idea if your recycling center allows 'take-outs' - none of ours does.lckstckn2smknbrls wrote: ↑17 Jan 2022, 20:39 There is a township recycling center not far from me. When I need big pieces of cardboard I check there.
Current project:
- 1
Hi,
If there are any homes under construction nearby, the windows and sliding doors often come boxed, and enormous pieces of cardboard go into the dumpster. Happy diving!
- 5
Appliance stores -- the delivery guys always have to get rid of the fridge boxes.
I always keep large pieces of cardboard around. Seems I always have a use for it.
Have Rod - Will Fish
