Transom Repair or Replace.
aaarneson
Phoenix
I have pictures attached and I am trying to figure out whether I should try to repair or replace.
If I repair what product should I use to fill in the holes etc.
If I repair what material wood should I use...
Thanks
Aaron
I would replace that given the splintering.
Any decent plywood would do - make sure to seal it good. Varathane oil based exterior Spar Urethane at minimum...two-part epoxy is better.
Any exterior grade plywood but never Pressure Treated Wood. BCX is a good compromise between cost and quality.
Thank you all...
I am think of two layers of this with titebond 3...the transom is 1.5" thick
https://www.homedepot.com/p/Cabinet-Grade-Plywood-Panel-Common-23-32-in-x-4-ft-x-8-ft-Actual-0-688-in-x-48-in-x-96-in-1077486/302610611
I just haven't decide to use oil based paint, spar urethane, or epoxy.
