- Joined
- Oct 1, 2011
- Messages
- 452
- Reaction score
- 229
- LOCATION
- SoCal
Preparing to replace and lengthen my 2"x4" carpeted bunks. Currently they are 5'. I will be adding additional bunk brackets (one to each side) and lengthening bunk boards to 7'( see my caveman drawing) . I am also going to add one additional keel roller with bell ends.
A few questions about set up.
The OEM keel roller that came with the Karavan trailer is the type below that has no bell ends. I will be adding an additional keel roller with bell ends. The purpose of additional keel roller is to spread some load as well as guide the boat as straight as possible when loading boat on windy days.
NOTE: I will also be adding guide boards to assist with loading.
My thoughts are that keel rollers serve to guide and rest keel, and not take on too much weight.
Still....how do you measure weight on bunks and rollers?
I have the one that came with trailer (no bell ends) I will place it about 2/3 forward of transom.
I will be adding the keel roller WITH bell ends near the bow area.
Questions:
1. Thoughts on additional keel roller with bell ends?
2. Thoughts on keel roller placements
3. Thoughts on lengthening bunks to 7' and placement of additional bunk brackets?
4. Should boat weight be primarily carried by bunk boards? If so, how much and how do you measure?
Additional thoughts?
Thanks
Questions:
Thanks
