- Joined
- Oct 1, 2011
- Messages
- 451
- Reaction score
- 229
- LOCATION
- SoCal
Purchased a new Lowrance Elite 9 Ti2 with 3 in 1 Active Imaging transducer. It's last year's model, but the price was great.
In previous Lowrance model's (different model head units and transducers), I recall the installation of the transducer recommending a certain distance from prop edge, mount to the right side of transom (to avoid prop wash on right turning props), and avoiding hull strakes.
This current installation instructions.... https://www.lowrance.com/en-sg/help--support/?guideId=535-060
do not refer to any of the above and simply state, "Chose transducer location."
My transom pics are attached.
Centerline to right edge of transom is 27"
Hull strake is at 14.5"
Prop edge is at just right of centerline blue tape.
Strake is at outer blue tape (14.5")
NOTE: I plan on using an approx 4"x5" piece pf 3/4'-1" starboard material and epoxying to transom and then mount transducer to this.
I used Marine-Tex RM321K FlexSet on a previous alum hull and it has worked great for HDPE and aluminum bonding.
QUESTIONS:
Why would install instructions change over the last few years?
Why no mention of which side of transom to install?
Why no mention of strakes, distance from prop edge, etc.?
Anyone install one of these 3 in 1 Active Imaging transducers on a same/similar boat hull?
Preferred place to mount give dimensions of my hull?
Thanks!
QUESTIONS:
Thanks!
