Toby from MO
- Joined
- Mar 23, 2009
- Messages
- 35
- Reaction score
- 0
Here you go Codeman...since you’re relatively new to outboard jets I thought I would post a few accessories for the jet foot that are available.
This is a poly intake to replace the existing cast iron intake. This particular intake was designed by a boat builder up in the northeast...it is molded with intake fins. Intake fins drastically reduces cavitation by helping direct water directly into the foot.
Here is another pic of a poly intake with aftermarket intake fins bolted on.
Couples pics of whale’s tail...from Trout & Sons. Helps boat plane faster. Not quite as effective as similar models used on prop motors...though does help getting out of the hole.
Here is a pic of a stainless 4-blade impeller. Stainless impellers are far more durable with resisting rock chips better than the aluminum. Similar to a propeller there are a few available choices with either different blade count and/or pitch to either provide a better hole shot or faster top end speed.
