Dang and I thought I was the only one.tomme boy said:No. But everyone here will say yes. If you want to make it 1-2 mph faster raise it up.
mrdrh99 said:I may try that, I've already put a 50lb bag of sand up front but the nose won't quite drop enough to get it going.... Top speed so far is 12.3... With a 9.9 I was thinking I could get at least 15-17
CedarRiverScooter said:You should reverse the exhaust cone. OMC put them on backwards 'cause Merc had the patent. The owners were suppose to figure out to reverse them on their own! It just taps off & back on.
BoatingCop said:A hydrofoil isn't necessary to get it to plane, you have issues else where that can probably be fixed. My 14' V-hull with a 9.9 planes just fine and does 15-18 MPH GPS. 21 is the fastest I've ever had it. What pitch prop is on the boat and what are the dimensions of the boat? It should plane, even if the engine is mounted a little low.
I still have no clue what you are talking about. Can you post a pic of the part in question? What range of motors does this apply to?CedarRiverScooter said:OK, I may be all wet, as I couldn't find any backup to that story on the web.
That is what the evinrude dealer told me when I bought a prop from them. They told me to reverse the ring.
stinkfoot said:I still have no clue what you are talking about. Can you post a pic of the part in question? What range of motors does this apply to?CedarRiverScooter said:OK, I may be all wet, as I couldn't find any backup to that story on the web.
