Need mechanic
Xpress_442
Port Lavaca, Texas
Hey guys, recently my tilt and trim seals went out. Naturally I replaced them filled it back up and bled it. Now it will only go half way up before it stops. I don't know what the problem is I put as much fluid as would fit and it won't work. Any ideas?
May have to bleed air out. May even have to reset the ram by unscrewing a bolt raise the motor by hand and re tighten to set the range. Not sure how its done exactly.
Thanks for the info guys I was at a loss. I'm gonna get some more fluid on my way home and try and fill it again
