Scooby
I have a 1988 allweld 16/60 Flatbottom,will a 1981 75hp Evinrude with an outboard jet plane this boat with 3 adults?
I would think so. I have a 1652 Lowe with a 60/45 Merc and it planes with 3 people fine. If you add too much weight/gear, it could be an issue with the flat bottom. Mine
Would a 115 /80 be too big for my 16/60 alweld?It should work well enough as long as your expectations aren't overly high and the boat is setup/balanced properly. Is it going to be a speed demon with 3 guys? No, but it should get you around just fine.
Did it make your boat tail end heavy?As long as the transom will hold it and the boat will float it I say go for it. I've got one on a 1760.
Would you happen to know what omc v4 2strokes a R series outboard jet will fit?
Thank YouDo you have the code off the jet unit itself? Outboardjets website does have some lists of which jets fit which motors but you have to search through them based on jet size.
Here's a pdf on their site for OMC and if you go down to the 2nd table it shows the V4 motors and the jet codes.
http://outboardjets.com/download/jet_drive_kits/Johnson-Evinrude-2022-2023-WEB.pdf
I will Thank YouWhere are you seeing on rainboats that the same jet fits the 48, 88, 112 motors? The numbered comments at the bottom of the page showing #22 and #23 refer to the AF93, AFC93 and R85-92 pumps like noted on the Outboardjets site. Your motor has the L60 or L60C pump which looks to be specific to the 55-75 hp motors. I would listen to what Outboardjets is telling you.
No but I know it’s a Model L pump I’m going to put the 75 on my boat and see how it does,Thank You for trying to help.Did you ever find the tag on your jet unit showing the model code? Mine is missing the tag for some reason but I know it's an original Mercury jet outboard so it's no big deal to me.
http://outboardjets.com/id-and-serial-numbers/
