- Joined
- Oct 1, 2011
- Messages
- 460
- Reaction score
- 239
- LOCATION
- SoCal
My previous thread discussed my trailer and its sizing to my boat. I wanted the tongue to be longer. I debated between 3' and 4'. Decided on 3'.
Purchased a Fulton Fold-Away Tongue bolt on kit (part # HDPB330301)
Removed coupler and trimmed trailer tongue by 2" (it was slightly squashed by coupler which was over-tightened.
Purchased a 3"x3"x1/8" section of square steel tubing. Purchased 4' as I was undecided on length when I purchased. After looking at what 4' looked like, I decided to go 3'. I cut it down to 3' with my abrasive chop saw.
Fulton kit requires 8 holes (4 on top, 4 on bottom) of each section of 3"x3" where coupler connects.....trailer section and new tongue extension. 16 1/2" holes in total!!!
Drilled holes, painted exposed raw metal in trailer portion (holes) and prepared for install.
Drilled new safety chain holes (1/2") rear of new fold-away coupler. Same paint on these holes.
Had a local guy powder coat my new 3' extension. It is flat black wrinkle finish to match the wrinkle finish of the Karavan trailer.
Installed new coupler and fold away coupler on my freshly powder coated extension.
All assembled and torqued.
Needed longer safety chains (approx. 5') due to extension. Decided to go with 6' coil cables so they would not drag while trailering.
All that is left is to extend trailer wiring. I'll run tag end through new 3"x3" section and exit under coupler.
Then.... Test to see how she tows and launches!
