Have you seen the motor running? I would want to see it running with the oil injection pump working properly. I bought my 1994 60/45 jet with a bad oil pump so I removed it and I premix all the time. The VRO pump on my old 99 Johnson 40 hp also went bad and I removed it and ran premix on that motor as well.
If the engine is new to you then get in there and replace the pump for no other reason that peace of mind and knowing the pump is fresh and ready for service.
Do you have a picture of the current one? I can check my boat, I had to add one to the hull along with the motor bracket because my motor is mounted so high it doesn't touch the water when it's tilted up with the boat at the dock. I'll see if I can find where I got it.
This is the one I think I ended up getting.
https://www.mercruiserparts.com/818298q1-anode-kit
