I have a '69 model 9.8 Merc 110. Here's a list of the parts I need.
carb kit (side bowl KB-8A)
Fuel pump kit ( 53240 stamped on the side.. it's rectangular)
Both fuel lines; the one from the tank connector and the one from the powerhead
Also need the kill switch and wires if possible, if not available would the motor run without the switch? I assume all the kill switch does is short the points out to kill the engine although I'm not sure if the switch is open or closed to run.
I can find the carb kit online but am having trouble finding everything else.
Maybe on the fuel lines I could find some brass fuel line fittings with hose barbs and just use regular fuel line.. Any chance of that?
Any help would be appreciated
