9.9 hp chrysler cutting out at idle, rough idle.HELP
Jay D
Texas
My sea king is cutting out at idle/low rpm like the timing is off but runs fine with choke on or high rpms. I see NO ignition adjustment , it has a rolling bar that floats on a piece of metal. I also cant get the recoil to retract, I just replaced the spring. No wonder I am NOT a mechanic and just a carpet cleaner. #-o
Alright, Make sure when you change your impeller that the water pickup tubes are alined properly. The outboard was getting to hot causing the spark to detonate at the wrong time. pull start was binding so the bushing was emeryclothed and put back together. My neighbor IS a mechanic and helped out a dummy, thank you Lord! :lol:
